I have the B+W normal sized MRC polariser, It is excellent, for cutting out glare & reflections from water & foliage adding contrast. It has brass rings which makes it slightly heavier that Alum frame. I'm not sure if brass is less likely to jam on a lens thread but I have never had of of these get stuck. (I jammed a Hoya UV once many years ago)
No significant vignetting. Anyway if i'm needing a polariser the lens is not wide open at f4 anyway.
Don't but the slim version of this filter for the DA15 or the DA35 macro as it will not fit inside the sliding hoods. (This might apply to the FA77 also. IDK)
mounted on DA15 with hood extended. notice the corners of the hood, just on the edge of the filter ring.
BTW the ND on the left is a Hoya ND400 (8 +1/2 stops)
