10-19-2011, 03:37 PM   #1
wrong focal lenght with tammy 17-50
So I finally got my copy and i am confused. at wide end (17mm) i noticed that both of my K-x bodies one with 1.0 firmware and second with 1.02 reads wrong focal lenght (45mm) !? Not with every wide angle picture but it happens. What do you think?
10-19-2011, 04:37 PM   #2
The in-camera reading is an approximation, so sometimes that might happen.
10-19-2011, 05:04 PM   #3
Just1MoreDave's Avatar
At the 50mm end maybe. An older lens like a Pentax-F zoom doesn't send as much data to the camera, so you might not see the exact FL. Maybe a third party lens has the same problems.
But the OP is seeing 45mm when the lens is at 17mm, which may be a problem for the SR. One strength of the Tamron is a long warranty; I'd take advantage of that.
10-19-2011, 07:10 PM   #4
krp
krp's Avatar
That's funny, I just noticed that yesterday. I shoot at 17mm quite a bit and a few pictures say 45mm instead. I hadn't noticed this before but I'll have to go back and check.
10-20-2011, 05:59 AM   #5
hm interesting.. so this is general issue
10-20-2011, 12:03 PM   #6
haven't noticed the problem on my copy. Using a Pentax Kx. I would clean the contacts, both on camera and lens, and then if that doesn't help, try the warranty route.
k-mount, lenght, pentax lens, slr lens
Vivitar 85mm f1.4 vs Tammy 90mm f2.8 vs Tammy 28mm-75mm f2.8 sany Pentax SLR Lens Discussion 5 06-05-2011 11:24 PM
manual lens macro focal lenght question Frank Bowler Troubleshooting and Beginner Help 5 12-10-2010 10:23 PM
focal lenght on digital vs 35mm lenses Bulldogface Troubleshooting and Beginner Help 5 01-26-2010 03:21 PM
How do you set 125mm focal lenght in K10D? FrancisK7 Pentax DSLR Discussion 3 08-29-2008 03:55 PM
Right focal lenght for shake reduction on s-mount lenses uPiX Pentax SLR Lens Discussion 13 01-31-2008 07:39 AM
All times are GMT -7. The time now is 07:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
