Hi altovintner,
Congrats on your purchase!
I would also suggest you look for a deal on an F 1.7x Auto Focusing Adapter. I use this with my ultra teles more than not for birding as it offers 3 distinct advantages:
1. 1.7x magnification and AF, of course. Your MF 300/2.8 will become an AF 510mm f4.8. The AFA with tele lenses does have a limited focusing range, so you have to prefocus the lens to get it within the AFA's range. This is not as much of a detriment as it sounds to be though, as once you've used it for a while, it becomes second nature, and this brings up the second advantage. . .
2. It acts as a focus limiter. My FA* 300/2.8 is the only one of my ultra tele lenses (I have a few. . .) that includes a focus limiter, and it's a bit fussy to use, IMO, even though it's got 3 distance ranges. The AFA, it acts as a natural focus limiter, and once you're in the range of the AFA to AF, slight focus corrections using AF are easy and quick, and if the camera misses AF lock completely, even a full lock to lock hunt takes only a small fraction of a second, and you're back in focus as opposed to a full MFD to ∞ with a normal AF lens. I'm probably not describing this well, but as a birder, I can tell you that the main reason why I habitually use the AFA is for the focus limiting function, though the 1.7x mag is a very close 2nd.
3. Once you've gotten the MF prefocus drill down, AF is extremely quick to lock, and it is, more often than not, dead on. The limited focusing range and the very light focusing elements in the AFA are the reasons for the very fast lock.
The Tokina should also be good enough to try stacked TCs. With all of my 300/2.8s I can use the AFA + a quality 1.4x TC to get 714mm f6.7. Even though this is a relatively slow max aperture, it's about the same as the Sigma 50-500 at 500mm, but you're shooting at 714mm. . . and you can still shoot at the lens' Minimum Focusing Distance (and sometimes a little bit closer).
Here are some samples with various camera/lens/AFA combos, all cropped a bit and PP'd to taste, except for the 100% crop:
*ist DS, Tamron SP 300/2.8, Tamron 140F 1.4x, P F 1.7x AFA. Handheld with no SR obviously. A lucky shot admittedly, followed by a 100% crop to show the wing feather detail. pretty remarkable for a 6 MP camera, IMO
Same camera/lens/TC combo, shot from a tripod.
K20, same lens/TC combo, shot from a tripod
K20, FA* 300/2.8, Sigma EX 1.4x AF APO TC, 1.7x AFA
Same as above
K-7, FA* 300/2.8, 1.7x AFA
Good shooting with your new lens!
Scott
