12-11-2007, 01:24 PM   #1
UV filter vs Protector
Hello everyone,
I want to ask perhaps a veeery newbish question... But I really would like to know what's the difference in picture quality, especially in sky colors, taken with uv filters and protector ones.
I know the theory, UV ones suppose tu completely stop UV rays, while protector ones generally do not change the spectre, but the glass itself eats UV spectre, as far as I remember from school physics.
I always used cameras with UV ones, but now I asked myself - do I NEED UV protection? I need to buy myself some filters soon and I'd be very grateful if anyone can take a pic with sky in it with UV filter and same pic with protector filter, so i could choose what ot buy.
12-11-2007, 01:29 PM   #2
travis_cooper's Avatar
I use uv filters, but only to protect damaging the lens. Although lately I have been hearing that I probably shouldn't because the filters mean that I am losing quality since they aren't up to par with my glass. Who knows, I can't tell much of a difference, I guess I just don't have a good enough eye.
12-11-2007, 03:15 PM   #3
QuoteOriginally posted by Snowcat Quote
I'm no expert but AFAIK there should be no much of a difference between the 2. also the protector filter should also be coated (like the UV Filter) to prevent some negative effects.
What I do know is that a Polarizer filter has effect on the Sky (makes it more blue) and it counters some reflections on non metalic surfaces.
12-11-2007, 04:01 PM   #4
Personally I don't use a filter to "protect" the lens unless I am shooting in harsh (wet, dusty, etc...) conditions. I always use a lens hood (hard plastic type, not rubber) to protect the front element.
12-11-2007, 04:18 PM   #5
Canada_Rockies's Avatar
QuoteOriginally posted by jbcampbell Quote
I used to use a UV filter on all my lenses for protection. I stopped doing that about 20 years ago. I have not had any damage since. I do use lens hoods at all times. I do not use a lick of the tongue and my tie with pizza sauce on it to wipe off the lens.
A lens hood protects against physical damage. It also reduces flare and all that as advertised.
If I am on a sandy beach on the West coast, I will put a filter on. It is easier to wipe down the filter than the front of the lens when salt spray and sand get at it.
12-11-2007, 09:34 PM   #6
SpecialK's Avatar
Here's the best filter/no filter thread I know of. Ho hum.
Filter recommendation - Digital Camera Resource Page - Forums
12-11-2007, 11:06 PM   #7
I prefer hoods, or even no protection to having a filter in front of my glass at all times.
With a filter, you lose the benefits of the wonderful SMC coating, and you'll be far more prone to flare.
I think "protection" is somewhat overrated, at least for anyone who is not a pro journalist or something. As long as you use due care, I don't think you'll have any problems.
12-12-2007, 10:17 AM   #8
kyrios's Avatar
I use Hoya UV HMC 62mm to protect my Siggy 30/1.4
To protect my DA40 and DA70, I use 2 cheapest 49mm uv filters instead of hood. Coz it's easier to plug and unplug 49mm universal lenscap rather than original lenscap of DA40 and DA70.
I broke the filter glass btw. But 3 filters should be better.
What i want to say is, if diameter thread is small (49mm or 52mm), put 2 or 3 filters without glass. Should be cheap since diameter is small. And only if vignetting won't occur (by stacking 2 or 3 filters).
If vignetting occured, replace the last filter with step-up filter.
If you use hood, it's not easy to attach the lens cap (but the best one). You choose.
kyrios
filter, filters, k-mount, pentax lens, pic, protector, sky, slr lens, uv
Hoya HD Protector Filter 58mm DaniRo Ask B&H Photo! 4 06-21-2010 07:47 AM
Hoya HD Protector Filter 58mm DaniRo Pentax SLR Lens Discussion 5 06-18-2010 09:42 PM
UV filter as protector lens? bingsean Troubleshooting and Beginner Help 8 03-25-2009 10:06 AM
Filter/protector suggestions Jasvox Pentax SLR Lens Discussion 7 12-16-2008 01:13 PM
UV filter or Clear Protector dazman Pentax Camera and Field Accessories 12 05-29-2008 05:15 PM
All times are GMT -7. The time now is 04:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
