Originally posted by dinneenp My sports lens in 86.2mm diameter so i'd be looking at 55mm set.
Would
Vivitar 55mm MACRO Adapter +10 and Case | eBay
work so.
I'm slightly confused (again) as everyone seemed to mention +7dpt but this is just one adapter and says it's +10.
It's not a set, just a single strong meniscus. This +10dpt has a working distance of 10cm / 4in; it's stronger than a DCR-250 which is +8dpt. Magnification at a focal length of 70mm is 0.7x or 1:1.4, in the macro realm. The Raynox is corrected for optical aberrations while the Vivitar meniscus isn't, but the Viv probably costs much less.
[I have three of them (various brands) but that's because I'm a perv and I stack them on tubes to make a very fast crappy lens, about a 35/0.9. They cost me ~US$10 each.]
That +10dpt is strong medicine for specific uses. It only hurts a little to spend a pittance more for a +1+2+4 set also. The +1dpt is good for portraiture, with a working distance of ~1m. Combinations of these allow a diversity of uses; you can go from +1dpt to +17dpt which is quite insane. Just make sure they're all the same thread diameter.
Quote: Also how will a 55mm set fit when the diameter is 86mm?
Step-down ring or rings. Get a single 86-55mm step ring (NOT 55-86mm, that's step-up). Maybe look for ring sets in case you'll want to use more adapters on more lenses. But for just one lens, a single ring is fine.
ALSO, if you're paranoid like me, you'll maybe want to go to a 58mm set and ring, rather than 55mm, just in case. The larger diameter will ensure no vignetting and might give better edge results. Remember, a meniscus is uncorrected and will be worst around the edges; a larger diameter should minimize this.
