Originally posted by clawhamemr I don't think the focal lengths will be the same. Also be aware that it will be full manual everything. You should get extremely good IQ because you definately would be shooting in the 'sweet spot' of the lens (right in the center of the image circle). If you can, try it out. I'd love to hear how it works.
Manual doesn't bother me that much. Manual focusing is fine by me and I use aperture priority a lot anyways, so all is good. What worries me though is will I get a similar angle of view as I would with a normal 35mm lens, i.e. will a 300mm 645/6X7 lens give me the same reach a 35mm format 300mm lens would? If this works, I may try to do it. Don't worry, I'll report back if I go through with it
Best regards,
Boucicaut
