Originally posted by causey
Use this tool to get an idea:
Focal length comparison tool, Tamron USA
Select "Tamron 10-24," then move the mouse cursor from 14 to 18mm. Note that you have three pics on which you can see the difference.
14mm is much wider than 18mm. Also, the Samyang is much, much sharper than the kit lens at any aperture. I've recently posted a thread with pics taken with this lens: Wide on the Fall
Just took a look at your site: fabulous pics!
Thank you man for the tool! That's helpful.. Yeah, many are saying that it is really sharp all the way around. =)
Originally posted by Lowell Goudge
The difference between 14 and 18 mm however is considerable. If you do a search on the forum somewhere thee is a FOV comparison for wide angle
I think I've read somewhere those comparison. I think they compared three UWA, Sigma 10-20mm, Samyang 14mm, and Pentax 12-24mm. They're almost have the same FOV, but the question is what camera did they use on the Samyang 14mm to compare it with those two UWAs. =)
Originally posted by kenafein
do you have a 20 or a 21 for your film camera? That's about what it would be.
Hmmm... That's another problem for me, 28mm is my widest for FF. hehe. =)
Originally posted by RioRico
10mm lens: APS-C AOV= 113 deg
14mm lens: FF AOV= 114 deg, APS-C AOV= 94 deg
21mm lens: FF AOV= 92 deg
Or so my spreadsheet tells me. Exact number of degrees may vary slightly depending on the exact sensor size.
Thank you man for the chart! Now I'm getting the idea on how wide the Samyang 14mm on an APS-C sensor (Pentax DSLR sensor). Hmmm... So the Samyang 14mm's AOV on APS-C is 94 deg, and the Pentax DA 14mm's AOV is 92 deg (according from the description at Pentax lens database), that means the Samyang's 14mm is a bit wider comparing with Pentax's DA 14mm...? =)
Man! If only I have the opportunity to test that lens itself in the field, I would not be confused. There's no shop here in our place selling the Samyang 14mm, and the only way for me to purchase that lens is through online from Hong Kong.
