Originally posted by canajuneh That does sound logical doesn't it....it was what I tried when no infinity symbol could be found The problem is that focus ring turns and turns and turns with no 'end' in sight!
Ah yes, I forgot that you would be dealing with quick shift.
I think if you switch to manual focus you will feel a slight resistance when you hit infinity (or close focus the other way).
If not, turning the focus ring to the right more than is known to put the lens to infinity will put the lens on infinity.
