11-03-2011, 02:12 PM   #1
Fl_Gulfer's Avatar
Clean Lens
As you can see that there is a spot (At 5 O'Clock)on the inside of my lens and I was wondering If I could remove the 4 screws and clean that stuff off my lens without destroying the lens.
11-03-2011, 02:30 PM   #2
Giveaway winner!
MysteryOnion's Avatar
It is not the four screws it seems. As with many lens and yours as well, the retainer must be spun off via a spanner...
If you are sure the spot is in the lens group and not on the outside, then you need to remove the outer ring to get under the group. Circled is the spanner slots. Some folks use improvised spanners... google "diy lens spanners" to see some examples or get an actual lens spanner.
You could also remove the dark shroud ring that is held by the two screws to try and get a finger hold on the retainer ring and spin it of without, however, it may be too tight to do by fingers alone.
11-04-2011, 08:13 AM   #3
Fl_Gulfer's Avatar
One of these?
Amazon.com: Spanner Wrench, Wide (Imported): Home Improvement
11-04-2011, 11:06 AM   #4
Giveaway winner!
Yes. It will depend on the slot thickness... about 1-1.5mm or file it down if not available.
11-04-2011, 11:49 AM   #5
Lowell Goudge's Avatar
unless is shows up in th eimages i wouldleave it alone.
just my $0.02
k-mount, lens, pentax lens, slr lens
Clean fungus prime lens Sunnyf16 Troubleshooting and Beginner Help 5 10-02-2011 05:39 AM
Worth It To Clean It? PK 28MM Lens magkelly Pentax SLR Lens Discussion 15 11-25-2010 04:15 PM
How to clean my SMC PENTAX DA 18-55 lens from the inside? Chiefram Ask B&H Photo! 6 08-15-2010 05:05 PM
How to clean lens rustynail925 Pentax SLR Lens Discussion 11 04-25-2010 08:54 AM
Clean Pentax SMC Lens trevorgrout Troubleshooting and Beginner Help 8 04-17-2010 05:46 PM
All times are GMT -7. The time now is 11:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
