11-08-2011, 10:10 PM   #1
littledrawe's Avatar
extension tubes, min focus distance & infinity
If extension tubes decrease the minimum focus distance of a lens do the tubes prevent it from focusing to infinity?
11-08-2011, 10:18 PM   #2
Laurentiu Cristofor's Avatar
Yes.
The only way to increase magnification without losing infinity focus is to use a teleconverter.
11-08-2011, 11:30 PM   #3
RioRico's Avatar
If you put a standard camera lens on extension (tubes and/or bellows) then yes, you lose infinity focus. Camera lenses are built to reach infinity focus at their minimum distance from the frame (film or sensor) where the lens' optical center is at the focal length distance. Pushing that optical center further away reduces the focus distance. No standard camera lens on extension can reach infinity focus.
The story is a little different with enlarger lense (ELs) and projector-copy-process-etc lenses, which lack a focusing mechanism. Those can be mounted on tubes or bellows or focusing helicoids selected for whatever focus range is desired. I generally find that such lenses longer than 80mm can reach infinity focus on my PK or M42 bellows. (I have a couple odd 60's that work too.) I need to put about 60mm of tubes behind a 162mm EL before it reaches infinity focus on bellows, which extended can focus very close.
A note on focus distance: A non-reversed lens cannot focus closer than its focal length, which is also where it reaches maximum magnification. No matter how much extension you put behind a 50mm lens, it can't focus closer than 50mm from its optical center. Reversed lenses are another matter, but we won't worry about that now.
distance, extension, focus, infinity, k-mount, pentax lens, slr lens, tubes
Extension tubes & 18-55 1:1 reproduction? Northern Soul Pentax SLR Lens Discussion 3 02-20-2011 05:31 PM
Macro w/ m42 Extension Tubes & Takumars bigjonnee Troubleshooting and Beginner Help 13 12-10-2010 11:33 AM
PKA AUTO FOCUS extension tubes ? netuser Pentax SLR Lens Discussion 16 07-14-2009 06:41 AM
Extension Tubes-No Auto Focus pentax4ever Photographic Technique 12 06-17-2008 05:44 PM
Focus distance between object and 50/f1.4 with extension tube/macro adaptor raider Pentax SLR Lens Discussion 43 07-15-2007 07:15 PM
All times are GMT -7. The time now is 08:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
