Originally posted by DaveHolmes They do suck... However... They are good fun...
The adapters are fun as long as you don't expect anything really *photographic* from them. Treat the output as raw material --shoop the sh!t out of those images -- make posters, matrices, animated GIFs, etc -- know their limitations.
Different types of fisheyes exist. All the cheap adapters AFAIK and the somewhat affordable lenses are frame-filling fisheyes, using various projections. Some of the exotic adapters and not-so-affordable lenses are full-circle fisheyes. The Kenko 180 Degree fisheye adapter is like that. I mount it on a medium zoom on my K20D. At 40mm and shorter, it's full-circle. From 60mm and longer, it's frame-filling. It's fun to play with fishy projections, changing the distorions.
Quote: It comes in a Pentax mount too (sometimes sold as 'Falcon' rather than Samyang) and is considerably cheaper than the Zenitar 16mm (at least here in the UK)
I see it going for US$300-400 stateside, vs about US$200 for the Zenitar. The Zen isn't nearly as fishy. They're not really in the same league, being roughly like the extremes of the DA10-17 range.
Quote: Chances are, you'll get it, use it for a week or so and then realise that fisheye isn't as cool as you thought it was anyway...
Yes, there's this problem. Extreme fisheyes have limited application. Crappy fisheyes... well, they have their own uses. Keep the image display size small and the crappiness isn't so noticeable. Just don't look too close.
