12-15-2007, 02:27 PM   #1
Tom Lusk's Avatar
Dumb question:
I often see lenses like this one:
Pentax-A* SMC 645 600mm 5.6 ED Lens 645N NR 27759 - (eBay item 290191716292 end time Dec-24-07 18:39:09 PST)
Beautiful lenses designed for 645 or 67 systems that sell for a fraction of what the 35mm equiv. lenses do.
Is there not ANY way these can be adapted for use on a K100 or K10???
12-15-2007, 02:53 PM   #2
There are no dumb questions - just dumb answers!
As far as my limited knowledge allows me it is entirely possible to put a 645 lens on a 35mm Pentax body if you use the proper adapter. Kind of like this.
A more detailed and intense search should produce cheaper examples of this adapter.
Another forum post on this subject is here.
Happy hunting!
12-15-2007, 02:57 PM   #3
It can be done, but probably is not wothwhile.
The lenses, being made for medium format, are bigger and heavier than even their 35mm full-frame counterparts. Adapters are available, but expensive -- about $150, if I recall correctly. The crop factor for a 645 lens on an APS-C sensor is approximately 2.2, so that 600mm lens would effectively become a 1320mm.
12-15-2007, 03:12 PM   #4
Being a medium format lens means it'll be very impressive quality as well.
12-15-2007, 03:22 PM   #5
OniFactor's Avatar
QuoteOriginally posted by little laker Quote
why does everyone say that? MF lenses actually can be LOWER quality, because of the bigger image area...
12-15-2007, 04:13 PM   #6
Canada_Rockies's Avatar
Usually, a 35mm lens will resolve better than a medium format lens of equal quality. The lens designer of the medium format lens has to cover a huge image circle, and the compromises result in lower central resolution, and that is where the 35mm frame or APS-C sensor is getting its light from.
12-15-2007, 04:33 PM   #7
creampuff's Avatar
QuoteOriginally posted by Canada_Rockies Quote
Really? Are you sure or are you guessing? The larger image circle to cover the larger format is why medium format lenses are physically bigger and cost a lot more than 35mm lenses, plus the equivalent focal length compared to a 35mm lens is longer. I have owned and used the Pentax 645 & 67s, Bronicas and Hasselblads and the MF lenses resolve just as as good if not better than a lot of 35mm lenses.
12-15-2007, 07:45 PM   #8
SpecialK's Avatar
Not necessarily. Crap can come in every size.
k-mount, lenses, pentax lens, slr lens
might be a dumb question but......... Digital Dustin Troubleshooting and Beginner Help 2 12-25-2009 06:59 PM
Dumb question Mallee Boy Digital Processing, Software, and Printing 2 01-25-2009 08:15 PM
This might be a dumb question... mchud Digital Processing, Software, and Printing 10 12-02-2008 12:59 PM
A Dumb Question? benjikan Pentax DSLR Discussion 35 04-03-2008 10:03 PM
Dumb Question billyclaymyers Pentax DSLR Discussion 9 06-26-2007 05:53 PM
All times are GMT -7. The time now is 01:57 PM. | See also: NikonForums.com, part of our network of photo forums!
