11-16-2011, 10:29 PM   #16
sterretje's Avatar
Just found https://www.pentaxforums.com/forums/pentax-dslr-discussion/64295-pentax-high-...post-here.html . This thread started in 2009 and shows that you actually don't need a K5 for good photos at high ISO
11-16-2011, 11:23 PM   #17
Laurentiu Cristofor's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
But I should add that for Al, this was just a suggestion, as it doesn't really fit his priority of getting faster zooms.
Darn, just realized I was replying to the OP. Please change third person to second person when reading this.
11-17-2011, 12:13 AM   #18
my view:
tamron 17-50 (cheaper than sigma + good optics, make sure u get a good copy / warranty)
tamron 70-200 (cheaper than sigma + good optics, make sure u get a good copy / warranty)
fa31 (would never let this one go); or switch for a sigma 30 1.4
K-5
i would be happy with the above kit, i have a lot of limiteds but if i was to keep one for usefulness in terms of lowlight / FL it would be the fa31. very versatile FL + excellent optics. if strapped for cash, i would swap the FA31 for sigma 30 1.4 ("normal"ish view on APS-C)
11-17-2011, 05:26 AM   #19
QuoteOriginally posted by al_undy Quote
Is the K5 that much better for low light?
Oh yes yes, yes yes yes.
So much better, that you'll run into low-light focusing problems long before high-ISO noise will start bothering you, probably.
11-17-2011, 05:31 AM   #20
Size/weight of the 2.8 zooms is a concern. Am I really going to go my daughter's Christmas concert and pull out a monster lens for a few shots to record the moment? Seems like overkill and I have always been a bit suspect of the folks who do. Anyway, current thinking is to start with selling the FA21 to help float the purchase of the k5 and go from there.
I'm much less well informed than others here, but:
I think you should keep your 21mm, get a Tamron 28-70 (or is it 75?) f2.8, maybe sell the DA 70, and keep the 55-300 that you have. Maybe a fast 50 as well.
Versatile, light, compact, economical set right there.
11-17-2011, 02:05 PM   #21
All,
... The upgrade to the capabilities of the K5 is obvious, particularly for the high iso. Al
If it were me, I'd keep the K7, get rid of the 55-300, keep the other lenses, and buy the Sigma fast zoom. IMO the upgrade capability of the K5 is far from being obvious as with proper PP in a dedicated NR Software (such as Neat Image), you'd be hard pressed to see a difference with the K5.
11-18-2011, 06:36 AM   #22
QuoteOriginally posted by regor Quote
Roger,
Thanks for the input. The K5 price is way down but is still not cheap so hanging on to the K7 is somewhat attractive. Your opinion regarding high iso on the K-7 seems contrary to others expressed here and general sentiment on this subject elsewhere. Can you post a before and after example that demonstrates this? Also, while I am not afraid to PP and I shoot 95% RAW, dealing with noise is one more step that I would rather not have to do.
Al
11-18-2011, 06:39 AM   #23
All,
It is interesting to see all of the support for the Tamron products. Most are driven by value (good optics for the price.) Again, lower price while maintaining very good optics is a strong argument for the brand. However, having had examples of both Tamron (pentax da 18-250) and Sigma (70mm EX Macro), I am drawn to the Sigma because of the excellent build quality, image quality, and HSM. Of course, I need to decide if these are worth an extra $200 or so.
The 21 is a lens that I have never felt strongly about, so it is definitely out at this point. The 43 is also likely out.
Thanks to all for your opinions on this matter. You have been most helpful.
Al
11-18-2011, 07:28 AM   #24
dgaies's Avatar
FYI, the Sigma 70/macro doesn't have HSM focusing.
11-18-2011, 08:01 AM   #25
sterretje's Avatar
QuoteOriginally posted by dgaies Quote
I guess al_undy is talking about the 70-200, not the 70
11-18-2011, 08:17 AM   #26
Thanks, I know that. I owned it. I was referring to the 17-50 f2.8 EX which does have HSM.
11-18-2011, 08:19 AM   #27
QuoteOriginally posted by sterretje Quote
Yes, that too.
11-18-2011, 08:20 AM   #28
dgaies's Avatar
Gotcha. From the previous post above I wasn't sure which Sigma you meant (and you had specifically mentioned the 70) in the line before) and I just didn't want you to be disappointed to find out later that it doesn't have HSM. I just picked up a Sigma 50/1.4 with HSM and it's excellent
11-18-2011, 01:09 PM   #29
just reread my response. sorry to sound so short with you.
11-18-2011, 01:55 PM   #30
Can't argue with HSM if that is a plus for you. But I don't think IQ is something separating Sigma from Tamron. Both know how to build lenses with excellent IQ. As far as build quality is concerned, the Tamrons are well built - they feel different than Sigmas, but I had no mechanical/functional problems with them. On the other hand, I had some issues with my Sigma 105 where I would mount it and the camera wouldn't recognize there is a lens mounted. I think it probably had some oil that got into the mount because I noticed that the A button had a tiny bit of oil around it. I kept cleaning the mount and after several times, I expect it exhausted the free running supply of oil, so I haven't had this issue anymore. Now that I think about it, I was lucky I was storing it with the mount down, otherwise who knows where that oil would have went. So I wouldn't say Sigma has better build quality than Tamron - they used to be known as SIGnificant MAlfunctions in the manual focus era and even today people complain about the varying quality across lens samples. That being said, they have stepped up their game significantly and produce many interesting lenses.
change, da, f2.8, k-mount, kit, lenses, light, lineup, pentax lens, quality, sigma, size, slr lens
Wisdom req'd to discern which flash would best suit K5 andrewdb Pentax K-5 3 09-12-2011 09:38 PM
The wisdom of Glass-Steagall (1933) jolepp General Talk 6 06-22-2011 07:47 AM
Words of Wisdom? Rupert General Talk 74 01-28-2010 02:07 PM
Wisdom from the past for 2010 Phil1 General Talk 44 01-04-2010 08:43 PM
Wisdom from the Future for 2010 Ratmagiclady General Talk 8 12-31-2009 11:06 PM
All times are GMT -7. The time now is 03:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
