01-05-2012, 12:48 AM   #16
vrrattko's Avatar
So I finally acquired 'K' 85/1.8 and it is pretty compact lens. I didn't make enough photos with it to make any final conclusions on this lens. Comparing to DA70 I found K85 at least equal in terms of resolution when taking photos of the same scene. Actually it seems to me that K has slight edge over DA in centre sharpness in apertures below f4, while they are moreless equal beyond f4. They seem to perform evenly at the corners. DA has marginally advantage in contrast. Not a bad performance for 30+ years old lens, matching the modern design. Interestingly I once possessed FA77 and found DA70 to be a better lens, so I would take any 'fa77 blows K85 out of water' posts with reservations.
01-05-2012, 01:13 AM   #17
I don't have the K, but I do have the M85/2 which is rated 'worst' of the Pentax 85mms and the FA*.
From my brief comparison of it against a FA77, it was its match in center sharpness wide open, so I'd expect the K version to be better.
Can't comment on CA resistance and hazing though as I did not stress test both lenses at that time.
The M85/2 is pretty bad at those 2.
Certainly no such thing as this lens blowing that out of the water.
The 77ltd is better if working space is a bit more limited of course.
01-05-2012, 04:01 AM   #18
arv
Just for interest here are tests of both K85mm and FA 77mm lenses.
A.
k-mount, pentax lens, slr lens
Post your "Park Bench" "or "Picnic Table" images tessfully Mini-Challenges, Games, and Photo Stories 1346 21 Hours Ago 11:08 AM
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 35 02-10-2016 09:10 AM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
Sports "Highside Exit" took 1st Place in DPReview "Missed It by THAT much, Part 1" Challenge MRRiley Post Your Photos! 27 02-21-2010 08:26 PM
All times are GMT -7. The time now is 09:04 AM. | See also: NikonForums.com, part of our network of photo forums!
