11-19-2011, 01:52 AM   #1
chromo's Avatar
PK lens won't fit
Hi all,
I just picked up another lens second hand but it won't fit my *ist-DL.
I thought it would fit straight on as it is marked P/K.
The left lens in this pic is the one I refer to..
As you can see the flange is much longer around the circumference and prevents the lens from being inserted far enough into the camera for mounting.
I will cut the flange to something similar to the norm, like the right lens, and then it should be fine to fit it.
My questions are...What's the flange for ?
Does it really need to be there in the first place ?
(and anything else I should know)
Chromo
11-19-2011, 02:53 AM   #2
RioRico's Avatar
QuoteOriginally posted by chromo Quote
It looks like the infamous Vivitar flange. It's there to protect against some bad mojo on some film cameras. It does nothing on dSLRs except get in the way. You needn't cut it -- just undo the screws holding it down and remove it. Stash the flange and screws, in case you ever want to sell the lens intact.
11-19-2011, 03:18 AM   #3
chromo's Avatar
Ahh The old bad mojo on some film cameras trick.
I think you've given me pretty good advice...I'll check it out.
Thanks for that.
Chromo
11-19-2011, 04:36 AM   #4
chromo's Avatar
Yep.
Easy to remove and fits now
flange, k-mount, lens, pentax lens, slr lens
So I need a 47mm lens hood to fit my 50mm lens? lovemehate Troubleshooting and Beginner Help 15 04-18-2011 12:51 AM
will the lens fit? kschmitt Troubleshooting and Beginner Help 4 01-12-2011 09:09 PM
Will this lens fit my kx? 4ngi3 Troubleshooting and Beginner Help 13 06-30-2010 11:33 AM
Oh no! I got a lens that won't fit! Ouroboros Troubleshooting and Beginner Help 15 03-23-2010 08:12 AM
Will this lens fit my kx ??????? spanky66d Troubleshooting and Beginner Help 7 02-18-2010 03:23 PM
All times are GMT -7. The time now is 08:26 AM. | See also: NikonForums.com, part of our network of photo forums!
