From my experience, the DA 12-24 does best without any filters. But being best suited for ultrawide landscapes, it will be inevitable that filters will be used a lot (GND, polarizing, etc.), so there will potentially be the risk of additional flare, no matter how good the filter that is used. At any rate any decent photographer should learn to use a lens hood to reduce the chance of flare from oblique light sources, and secondly, know how to clone out the really nasty flare spots during post processing.
For an
ultrawide zoom lens, I personally think the performance from the DA 12-24 is terrific given the number of lens elements it has and possible amount of internal reflections that is well controlled. Seriously, I think it is pretty pointless to make a direct comparison between the DA 12-24 and the DA 15 because one is a zoom that covers a lot wider FOV and potentially subject to more extraneous light sources that could induce flare versus a compact prime ultrawide that has fewer elements and therefore can be made more compact and should in theory have better aberration control. For those taking IR photos, one thing to note is the DA 12-24 does show hot spotting in the center while the DA 15 does not. Both are good lenses, sharp even wide open so it is up to the individual photographer to choose between FOV versatility versus size and portability. Simply put, the wider FOV range from the DA 12-24 makes it more versatile but also demands more care in composition at the widest setting.
DA 12-24 without filter - sun in the center
DA 12-24 without filter - sun at the edge
