11-20-2011, 06:22 PM   #1
K-10d lens mount help
I dug out an old Spiratone F400 6.3 to try on my K-10d but I don't have any mount adapters. The lens has internal threading on the tube. Any ideas about which mounts I need to get it working on my K-10d.
11-20-2011, 06:45 PM   #2
Sounds like a screwmount: Pentax Mount Adapter K 30120 B&H Photo Video
11-20-2011, 07:08 PM   #3
That Spiratone (and all the other names it went under) is an M42 screw-mount. But the mount is screwed onto the barrel -- which is also threaded -- and the mounts often come off. If there is no chrome part then you're actually missing the mount. I suspect the other threads are like a T-mount which is commonly used on telescopes I think. Just something to watch out for...
11-20-2011, 07:08 PM   #4
jatrax's Avatar
Internal thread on the lens? Can you post a picture or measure the thread diameter? Might be a T-mount or part of a T-mount.
11-20-2011, 07:13 PM   #5
rvannatta's Avatar
the things I bought from Spiratone tended to be T mount.
11-20-2011, 07:16 PM   #6
I have that lens under a different name -- Tele-Lentar I think -- and the m42 mount will often try to come unscrewed from the barrel. The internal threads do look T-mountish, but I don't have a T adapter ring so I'm not sure.
11-20-2011, 07:47 PM   #7
RioRico's Avatar
My current Spiratone Telephoto 400 f/6.3 is definitely T-mount. So was the one I had 35 years ago. A T-mount or T2 lens has the same thread diameter as M42, but a different pitch; and the lens-to-frame (film or sensor) distance is longer than M42. DO NOT TRY TO FORCE AN M42 ADAPTER ONTO THIS LENS!! T2-PK adapters are cheap and common.
11-20-2011, 07:51 PM   #8
Does that have a mount on the barrel or are the threads on the barrel itself? Mine has an M42 mount and I've seen it many times with same. The M42 mount that is on mine is not an adapter -- it is supposed to be permanent but the little screw is busted or loose.
11-21-2011, 02:14 AM   #9
RioRico's Avatar
Mine (past and present) have T-mount threads on the barrel. I haven't seen any that are M42-native. I thought Fred Spira was too cheap to have variant versions made. If your M42 mount is knurled and has|had a grub screw, then it's probably T or T2 also.
11-21-2011, 09:09 AM   #10
Yeah, mine is same, but the m42 mount looks like it came with it and was meant to be attached permanently rather than just a T-mount adapter ring. That lens comes under at least a dozen different brand names -- not sure who actually made it.
11-21-2011, 06:35 PM   #11
The threads are internal in the tube. I don't have any mounts I can find so basically I have the lens tube with internal threading. I'll try to get a picture up and rolling. If it is a T-Mount d I screw it into the tube threads and it attaches to the camera. Sounds too simple.
11-21-2011, 06:47 PM   #12
Here are the threadings on the tube. Sorry for the pic size.
11-21-2011, 11:57 PM   #13
RioRico's Avatar
QuoteOriginally posted by sagecreeper Quote
Female threads? Non-standard, and definitely not M42. That looks like it needs a special adapter; all that I know of would need male threads on the tube.
11-22-2011, 12:16 AM   #14
I took a closer look at mine. I guess it is just a Tmount with an M42 ring. The one in the picture looks like the entire Tmount has been removed. Mine has some screws near the end of the barrel that look as if you removed them would allow unscrewing of the Tmount from inner threads. But if you did that it looks like it would take that whole inner grooved area with it, which is still shown in the picture above. Don't know what's going on there, but it sure seems like you're missing a part or two.
k-10d, k-mount, lens, mount, pentax lens, slr lens
Einstellung Pentax K 10D chickenherby Troubleshooting and Beginner Help 5 07-15-2011 10:11 PM
New PF user, JUST got K-5 to replace K-10D GrantMeThePower Pentax K-5 16 07-01-2011 07:30 AM
Lense mount help? rtrampe30 Troubleshooting and Beginner Help 6 12-24-2010 05:52 AM
Time exposures with K-10D. flashcactus Troubleshooting and Beginner Help 6 05-30-2010 10:08 AM
teleconverter for K mount lense prblack.6206 Pentax Camera and Field Accessories 6 05-05-2008 06:59 AM
All times are GMT -7. The time now is 03:10 AM. | See also: NikonForums.com, part of our network of photo forums!
