11-21-2011, 10:40 AM   #1
31mm ltd lens build question
Hi guys, I just notice recently that front part of the lens is not firmly built into the lens. when I press the front element light, it moves in and makes noise. Is it normal? Mine is AIV. Thanks!
11-21-2011, 11:02 AM   #2
pezmaker's Avatar
Sounds like you're physically forcing the autofocus mechanism to move. I'd try to avoid doing that.
11-21-2011, 11:10 AM   #3
QuoteOriginally posted by pezmaker Quote
I didn't force it to move, it moved when I only applied light(reasonable) force on it.
11-21-2011, 11:33 AM   #4
QuoteOriginally posted by wishlf Quote
That's not what you said in your OP. You said "...when you press the front element hard, it moves in and makes noise...".
So which is it? Are you applying light force or pressing hard?
11-21-2011, 12:24 PM   #5
Let me correct this, I pressed it hard once, it moved and made some noise. Afterward, I discover that when I turn the hood with light force, it exhibits movement.
11-22-2011, 10:00 AM   #6
drougge's Avatar
Mine (made in japan) also has some play in the front part. It's probably normal, but I don't like it. Doesn't make noise though, but maybe you pressed it harder than me.
11-22-2011, 10:15 AM   #7
QuoteOriginally posted by drougge Quote
Ok, I guess it's normal then. Thank you very much for your reply.
11-22-2011, 12:00 PM   #8
nah
I purchased one last week and now it's on it's way back to Adorama (awesome service btw). Mine not only felt very loose, but there was major back focusing issues.
I will try to hold out for a MIJ on the used market.
front, k-mount, lens, pentax lens, slr lens
Computer Build: SSD and Photoshop question noVICE Digital Processing, Software, and Printing 22 10-09-2011 02:04 PM
Question about FA 31mm sharpness at f/1.8 mr.sinha Pentax SLR Lens Discussion 41 07-08-2011 02:31 PM
31mm FA limited f1.8 lens question olivemike Troubleshooting and Beginner Help 7 05-02-2011 07:33 PM
Question regarding FA 31mm f/1.8 Mystic Pentax SLR Lens Discussion 11 03-18-2011 04:38 AM
Dropped a lens! (DA Limited build quality?) ADHWJC Pentax SLR Lens Discussion 10 10-16-2010 10:01 PM
All times are GMT -7. The time now is 07:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
