Originally posted by Nick Siebers Here's an inexpensive option no doubt laid out in Rio's cheap macro tutorial - M42 to K adapter, M42 bellows, Takumar preset 135mm or 200mm. I had both lenses, kept the 135 because the 200mm gave me too much working distance. Of course, if you want to use your FA50 (and who wouldn't?) the 2X TC maybe the way to go.
An old tale: Back in the day (circa 1975) I had an Olympus Pen-FT, a half-frame 35mm SLR with frame size very close to APS-C. What a beauty! And I had a (and still have another) T-mount Spiratone 400/6.3 long lens, and a shoulder stock. What beasts! I built a rig of 2X TC, tubes, bellows, and long lens, mounted on the shoulder stock. Loaded with Tri-X pushed to ASA 1000, out in bright sunlight, I could shoot closeups of rattlesnakes in the wild from a safe distance, like 3-4m.
If that kind of working distance isn't needed, putting a 100-200mm lens on bellows and/or tubes makes good sense. My bellows all extend out to about 140mm, so mounting a 135mm will reach 1:1 magnification, and a 200mm will reach 1:1.4. Such primes will work fine if edge-to-edge flatfield sharpness isn't necessary. Center the subject and to hell with the edges.
_________________________________________________
Good rules,
tim60! I'll throw in my bidding strategy:
Bid low; bid often; lose 99% of auctions; don't sweat it, another will come along shortly. If you *do* find a good candidate, figure what it's worth to you and don't go much beyond that.
I'll disagree a bit on body cosmetics. My two fine macro lenses were somewhat battered but work just great. But be sure the glass is in very good condition. Small traumas that may be unnoticeable at normal shooting distances can kill macro shots.
