11-22-2011, 10:47 AM   #1
Focal 2x converter on K-7 Yes, No?
I have a 2X converter and want to know if it is compatable with my K-7. I am skeptical as I don't want it to have conflict and get stuck on my camera.
Thanks!
11-22-2011, 10:51 AM   #2
Lowell Goudge's Avatar
If it is a K Mount, and specifically NOT a KA/R (Ricoh K mount) then it is ok. What does it say on the teleconverter
11-22-2011, 12:35 PM   #3
Nowhere Matt's Avatar
I have a Focal MC 2X converter that is designed with a completely non-threatening Ricoh pin. Mine is marked K-R just about opposite of the lens release.
The Ricoh pin is the rounded type and has never presented a problem with my K10 or K-7. I don't believe it sticks up enough to cause problems.
A brief, previous discussion here
And just for the record, in some instances, you can just enlarge or crop the image and it will look just as good as an image taken with some of these less expensive teleconverters. You may find your own way, however.
11-22-2011, 01:56 PM   #4
hcc
hcc's Avatar
Each TC is different. First check the Ricoh Pin. In the absence of a pin and if a bayonnet K-mount, the TC should fit on the K-7. However check if your TC has AF. With AF TC, not all lenses work well and you may need to conduct some tests. I have a Tamron TC 2X and all MF lenses work fine, but only some AF lenses work well.
Hope that the comment may help.
2x, 2x converter, converter, k-7, k-mount, pentax lens, slr lens
focal length pentax k-x Photographic Technique 9 11-22-2010 12:41 PM
focal length ewig Troubleshooting and Beginner Help 11 07-23-2010 09:32 PM
focal length landscaped1 Troubleshooting and Beginner Help 48 05-05-2010 03:04 PM
focal length on camera using sigma 170-500 and tamron 1.4 af tele-converter jon pafford Pentax SLR Lens Discussion 2 03-01-2010 08:00 PM
Setting focal length with tele-converter chiggerbyt Troubleshooting and Beginner Help 2 02-04-2010 10:42 AM
All times are GMT -7. The time now is 07:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
