11-23-2011, 12:25 PM   #1
Hayob's Avatar
Helios-44 F2. problem
Hey eveyone, Recently ive picked up a Zenit E with a Helios-44 F2. The lens has lots of fine scratches witch are visable when look thourgh both elements and the focusing ring seems a bit lose and is really stiff, Its so stiff when turned it unscrews the lens from the camera body! Anyone got any ideas on how to fix this also i dont want to much money on it really?
11-23-2011, 12:48 PM   #2
Deimos's Avatar
The fine scratches could be fungus. Do they look "web-like" at all?
I believe there are two "focus" rings on the lens, one is the actual focus ring and the other is to open/close the aperture for to allow for focusing (I believe).
Are you sure you are turning the right ring?
11-23-2011, 12:54 PM   #3
Hayob's Avatar
hey thanks for the reply, there a bit like a web, there all over the place really. And im turning the right ring as when you look thourgh the viewfinder it goes into sharp focus when turned etc.
11-23-2011, 01:00 PM - 1 Like   #4
Deimos's Avatar
QuoteOriginally posted by Hayob Quote
It is likely then that it is fungus rather than many fine scratches (unlikely). Which sucks but is quite common. Likely the shots you take with this lens will be hazy or offcoloured due to the fungus. You may be able to get it cleaned but likely cheaper to find another 44-2 for like $20-30 on here
This is what fungus can look like fyi:
lens fungus - Google Search
Some others might chime in about what can be done for stiff focus ring. At this point thought I would say you might be best looking for a second copy.
I spent $100 on a zebra CZJ 35 f2.4, the first used lens I bought, didnt know what to look for, it was loaded with fungus and it has sat on my bookshelf as a "lesson learned" ever since
11-23-2011, 01:13 PM   #5
Hayob's Avatar
Im not to sure im pretty sure it is really fine scratches. Thanks for the info though on the fungus
11-23-2011, 01:29 PM   #6
boriscleto's Avatar
Just so we're clear.
If you turn the Diaphragm Ring too far it will unscrew the top of the lens from the bottom of the lens.
My lens also bas what looks like lots of scratches, probably fungus. It just gives the lens that much more character. Who needs a Holga?
11-23-2011, 01:35 PM   #7
Hayob's Avatar
so is there anyway of fixing this? thanks for reply too
11-23-2011, 02:15 PM   #8
Sometimes, the old grease is congealed. WARNING: I am not giving you this advice, just telling you what others have done. A tiny - tiny - drop or two of lighter fluid into the focus ring has been REPORTED to sometimes loosen the grease up a bit. Do not use too much. Just a drop or two and let it set over night, then try it. You don't want to run grease into the inside of the glass lenses themselves.
11-23-2011, 11:45 PM   #9
mikeSF's Avatar
ultimately, you probably want to open it up and clean off the crystalized grease and start fresh.
that said, i have used lighter fluid and find it to be an excellent temporary aid in loosening up a really sluggish ring. also a small amount of heat (ie warming the lens in window light before working the ring over and over by hand.
the lighter fluid evaporates instantly and does not leave any detectable residue so even a sloppy overapplication is not likely to cause any problems.
f2, helios-44, k-mount, lens, pentax lens, slr lens
Sibling Rivalry: Helios 44M vs. Helios 44M-4 stevebrot Pentax SLR Lens Discussion 36 08-03-2013 09:31 AM
People 'O Helios O' Helios where art be? JohnBee Post Your Photos! 6 03-12-2011 07:19 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
For Sale - Sold: M42 Helios 44M-6 MC 58mm F/2 & Helios 44-2 58mm F/2 donTTouchonlywatch Sold Items 6 12-25-2009 02:16 AM
All times are GMT -7. The time now is 12:18 PM. | See also: NikonForums.com, part of our network of photo forums!
