12-18-2007, 10:19 AM   #1
PENTAX DA 10-17mm Fisheye Lens
Hi All,
I was considering a wide angle lens with the ability to have fisheye field of view.
Does anyone have the pentax PENTAX DA 10-17mm lens, and if so, could you please tell me if it will allow a standard wide field view along with the fisheye cropped look?
Also, what is a decent price to pay for this lens? I seen it for about 380.00 but wondering if that may be too expensive.
Thanks
David
12-18-2007, 11:09 AM   #2
and
standard wide field view... u mean non fisheye. its less fisheye at 17 than 10, the fisheye effect will be more apparent depending on the subject and how your frame the shot. I have seen fisheye shots at 10m that I was very surprised when I heard they were actually fisheye shots because they looked rectiinear.
In any case you can correct the fisheye distrortion using software, I beleive ptlens was the program?
btw the pentax 12-24 covers 99 degrees at 12mm, the 10-17 covers 100 degrees at 17mm so its a tiny bit wider at 17 than the 12-24 at 12.
pps when you use ptlens to correct the distortions you will have to crop out a bit of the image, it will still be very wide thoguh
12-18-2007, 11:13 AM   #3
Ole
Ole's Avatar
Here are some samples of my shots with this lens. I like it a lot, and it is sharp.
DA10-17 Gallery
12-18-2007, 03:43 PM   #4
I just got the lens. Here are a few test shots with it. I used no flash, a tripod with pistol grip head, a bowl of wooden fruit, and the camera set to 10mm with the lens about a few inches away from the subject. I know I will get a lot of fun from this lens. I can't wait to try it outside.
12-19-2007, 12:02 AM   #5
SpecialK's Avatar
Here's a comparison of the 10-17 vs 12-24 over the same range.
12-19-2007, 06:32 AM   #6
Thnaks for posting the comparison. Interesting. ch
12-20-2007, 03:58 PM   #7
Great Information
Great information. Thank You all.......!!
- David
10-17mm, da, da 10-17mm fisheye, field, fisheye, k-mount, lens, pentax, pentax da 10-17mm, pentax lens, slr lens, view
Wanted - Acquired: Pentax DA 10-17mm or other similar fisheye lens epa4wd Sold Items 1 10-28-2010 06:04 PM
For Sale - Sold: Pentax 10-17mm Fisheye Lens (Worldwide) knumbnutz Sold Items 2 09-05-2010 07:24 PM
New lens-Pentax 10-17mm Fisheye lesmore49 Pentax SLR Lens Discussion 6 10-21-2009 11:33 AM
For Sale - Sold: Pentax SMC-K 17mm F/4 Fisheye lens. Donkeypunch Sold Items 7 02-04-2009 09:24 AM
All times are GMT -7. The time now is 02:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
