Originally posted by falconeye I applaud your effort.
Unfortunately, as in most such tests, no conclusions can be derived.
A number of points to watch in similiar tests:
- have high contrast in the subject (done, great!)
- provide crops (done, great!)
- eliminate defocus blur, either by a focus series or by small enough aperture. 300mm/5.6 or 54mm is still a big aperture! Manual focus or LV focus is not good enough!
- eliminate shake (1/250s on 300mm may not suffice with many tripods! Use separate flash or attach the camera to a big stone)
- Use the lens' sweet spot aperture. For the 300/4.5, it is f/6.3 rather than f/5.6.
- Have detail near the sensor's Nyquist frequency, like a measurement scale in the proper distance or a star chart. Because contrast decreases more quickly than resolution with such combos.
Your comments made me go back and look at the results again, and there are a couple of additional points to consider. BTW I agree with your comments, specifically focus blurr, and use of flash, however that is one of the points I will discuss further below.
I don't see any mention of how focus was actually achieved? It would be interesting to know for certain, i.e. live view, manual or auto focus. THis is specifically because the lens and any 1.4x to 1.5 x TC would be at the limit of reliable AF confirmation for auto focus. To add onto that, the SMC-F 1.7x AF converter is about 1/3 of a stop beyond reliable AF ability, which is really only reliable at F4 and below.
There is mention of deliberate under exposure, due to the use of the TC, however this is not correct, and will be a finction of the TC and the camera. SOme TC's, specifically the SMC-F 1.7x AF converter, but perhaps others, modify the aperture data and feed true aperture back to the camera, and should not require any adjustment, additionally some cameras are quite reliable in metering, others (K10D and K20D specifically) are very poor if the true aperture is not known, therefore the compensation should or could be different for each. A better way to do this would be to use a constant exposure value for all the sample shots, however, this gets difficult because the 1.7x will need a different lens setting to the others.
Also, along the lines of constant exposure etc, how was this really controlled, because if some TCs modify the maximum aperture setting, then when setting to F5.6 may result in a different true and total aperture than other lenses?
Also depending on control of exposure etc, if the variables of each TC and aperture reporting are correctly compensated for, using a true constant exposure would show the efficiency of each TC and that would also be of interest.
As for flash, I agree, but again, this is very highly dependant on whether the TC properly corrects for the maximum aperture. Unless the flash was set to manual, there could be highly varrying results.
Aside from the issues above, all of which should be addressed, the actual resulting images are all quite good, and show that using a good TC on a good lens can produce acceptable images.
