Originally posted by Dean31 To use the dremel modification method....I cut off the lock-release pushbutton that is protruding? I assume this is what is preventing the lens from turning into place? (I realize it won't lock on if I do this).
NO! The problem with OM (and similar C/Y) mounts is that the bayonet flags are just a smidge too thick to fit under the PK mount lugs. I use the Dremel blade to shave away a little of the flag metal, to taper the flags so they WILL force-fit. I then cut a small slot in the lens base for the PK locking pin to engage, for a more secure fit.
The OM lock-release button is not in the way of anything. The OM stop-down button is another matter. As-is, a modded OM lens would only work on the PK camera with the lens aperture wide open. Two options here: 1) unscrew the lens base, remove the stop-down button, and jam its spring to hold the iris closed to whatever aperture setting you use. Or 2), jam the button down -- a bit of metal tape works.
With the bayonet flags tapered, the locking slot cut, and the stop-down button taped down, the lens can still be used on OM cameras -- just remove the tape! This is about as non-destructive a mod as I can devise.
I have a few posts here dealing with such lens mods. I need to compile them into an article, yes I do. But heed this: Before trying any lens-chopping, buy a set of ultra-cheap PK macro tubes, about US$7 shipped from China. The mount section serves as a great test-bed and inspection port. Set an OM or C/Y or Nikon or other lens on it, and you can see exactly what parts of the lens and mount foul each other, thus what and how much to cut.
