12-19-2007, 08:15 PM   #1
Flaco's Avatar
Thoughts on FA 50mm 1.7
I was at a local photo store today they had one in stock. One of the employees said he liked the 1.7 better then the 1.4. Said he felt the 1.7 was sharper then the 1.4. So I was wondering what people that have USED BOTH thought about it.
12-19-2007, 08:47 PM   #2
Buddha Jones's Avatar
That is a true statement, but they seem to even up when you back them both up to f/2. The general understanding is the f/1.4 is the bokeh king and the f/1.7 is the sharpness king. I have used both, and have since sold them both, and have regretted it ever since.
12-19-2007, 09:16 PM   #3
Ivan Glisin's Avatar
QuoteOriginally posted by Flaco Quote
I owned M50/1.7 which is optically the same as A and FA. Also, I currently own A50/1.4 which is optically the same as FA50/1.4. Here is my experience:
M/A/FA 50/1.7 is sharper than A/FA 50/1.4 for the good reason: 50/1.4 has (intentional) imperfection: field curvature and spherical aberration are more pronounced than with 50/1.7 and Pentax itself is NOT recommending 50/1.4 in combination with extension tubes or close-up lenses, while 50/1.7 is fine to use for macro work. However, due to pronounced field curvature and spherical aberration 50/1.4 has one big plus: "creamier" bokeh. Since 50/1.7 is more "technically correct" it results in better sharpness while producing bokeh that some people find to be somewhat "harsh", although it is very good as well. (FA35/2 AL is getting similar comments about the "harsh" bokeh for the same reason, I own FA35/2 and I do not complain.)
Bottom line: both are excellent lenses. 50/1.4 is better if you are after smoother bokeh and if it is acceptable to shoot at f/4-f/11 for optimal sharpness. 50/1.7 will serve you better if you are after improved and more uniform sharpness across the frame at all apertures, and if you want to combine it with extension tubes or close-up lenses for macro work, assuming you are fine with technically cleaner (not bad!) bokeh.
12-20-2007, 01:28 AM   #4
Kentax's Avatar
interesting. This just about sums up my concerns with the FA 50mm 1.4.
12-20-2007, 04:33 AM   #5
creampuff's Avatar
QuoteOriginally posted by Ivan Glisin Quote
... Pentax itself is NOT recommending 50/1.4 in combination with extension tubes or close-up lenses, while 50/1.7 is fine to use for macro work.
Extension tubes can be used on the Pentax 50mm f/1.4 so long as the magnification does not approach life size. (info from the Pentax Auto Extension Tube K manual that I have). I have tried the FA50 f/1.4 with different combinations of the Pentax Auto Extension Tube K and the image quality isn't very good at the corners when the tubes are stacked up (compared to a budget A50 f/2).
Other than macro use, I think the FA50 f/1.4 is a fine lens.
12-20-2007, 08:12 AM   #6
Flaco's Avatar
I have a manual M50 1.7(vivitar). But I'm wanting to upgrade to a autofocus 50mm. So just wanted to get some opinions on the FA's.
fa 50mm, k-mount, pentax lens, slr lens
People Two thoughts..... vikingo Photo Critique 5 07-21-2010 07:22 AM
My thoughts on the K-7 Mikke Pentax DSLR Discussion 12 07-25-2009 02:50 AM
Pentax 50MM F1.7 SMC F Thoughts and opinions... Scottie137 Pentax SLR Lens Discussion 9 12-18-2008 03:57 PM
My thoughts about DA* 16-50mm sychen Pentax SLR Lens Discussion 11 10-10-2008 09:35 AM
Any thoughts on the Sigma 18-50mm f/2.8? craig1024 Pentax SLR Lens Discussion 30 04-18-2008 04:21 AM
All times are GMT -7. The time now is 06:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
