I did the search and I've read a bunch of threads related to the issue. However I have not seen this particular one addressed.
I have a new K5 + Tamron 17-50mm f/2.8. I also have a Pentax 15mm f/4.0 Ltd lens.
The Pentax lens is spot on, no AF adjustment needed.
The Tamron at 50mm requires (at least) -10 adjustment (it is front focusing),
at 17mm it is however noticeably back focusing. Adjustment +3 seams to fix that.
As far as I understand it is correct that AF is different at different focal lengths. So, can a zoom lens be optimized for AF at all focal distances at all? In my case the range from -10 at the long end to +3 at the wide end seems too much, kind of kills the whole point of AF fine tuning.
Your input is valuable! I need to decide what to do with the lens. Other than this back/front focusing issue I really like it.
If you own the lens, could you please post your data for wide/long end focusing?
Thanks
