12-22-2011, 04:17 PM   #16
Laurentiu Cristofor's Avatar
QuoteOriginally posted by ducdao Quote
It's hard to tell without physically trying the lens, however, Pentax K and M lenses are known to be extremely precise and smooth for their focus ring. They are unmatched. So when comparing others to those lenses, one need to expect a bit less.
Unmatched? Hardly. The Takumars are even smoother. Modern Cosina lenses are smoother still. My Sears 50/1.7 is indistinguishable from the K/M lenses I used - it actually feels even better built.
QuoteOriginally posted by userage Quote
Sorry to re-bump, This is to anyone here who has the Rikenon
Do you find the focus ring slightly stiff? I wouldn't say stiff but it's not light as say my kit len's focus ring. Or is that normal for an old lens?
You are comparing an AF lens whose focusing ring is loose so that the AF motor doesn't have to fight a lot of friction, with a MF lens that has an amortized movement, so it doesn't slide away at the slightest touch when you just want to preset focus at a given distance. Sounds to me like you're describing this difference and not stiffness. Stiffness would mean encountering actual difficulty with the rotation of the ring, such that it becomes obvious you are making an effort to rotate the focusing ring.
12-22-2011, 04:28 PM   #17
userage's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
Yeah I thought it could be that but I wasn't sure how to describe it without writing a lot.
Thanks for clearing that up though.
50mm, f1.7, k-mount, pentax lens, slr lens
Any IQ comparisons between the 35mm 2.4 and old M50mm primes? NogBoy13 Pentax K-5 10 08-02-2011 06:27 AM
Lens comparisons normhead Pentax SLR Lens Discussion 5 01-01-2011 04:39 PM
Standard (or walkaround) zoom lens comparisons Buschmaster Pentax SLR Lens Discussion 18 12-31-2009 11:41 AM
Test: DxO K20D - full size comparisons falconeye Digital Processing, Software, and Printing 6 11-03-2009 03:42 PM
Please post comparisons images between the 18-55mm kit lens, SMC A 1.7 and 2.0 50mm. shaolin95 Pentax SLR Lens Discussion 21 02-10-2008 07:39 PM
All times are GMT -7. The time now is 09:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
