Originally posted by chickenandavocado wasser:
perhaps the reason for vignetting is because if you step down after the hood, the entrance of light might be less as opposed to step down straight away?
Oh, absolutely it is. However, I do prefer this arrangement for both the protection it gives and the more compact hood. This arrangement is one inspired by
SOldbear who was, I believe, inspired by the design of the Pentax hood for the DA 40mm. All mine are reduced at the end to either a 49mm or 30.5mm.
The vignetting under these circumstances is likely never to be a problem for me. My hood with the stepdown ring at the end does not vignette and I'm not likely to use any filter with my 31mm. However, if I did, the vignetting is so minor and only visible under extreme conditions, f1.8 and focused at infinity. I'm pretty sure it was gone by f2.8. So, I still wouldn't hesitate to use it.
