12-23-2011, 02:54 PM   #1
Best lenses for my children activities?
I am new to Pentax.
I used to shoot Olympus, very nice cameras and lenses, but the small sensor has its limits. So after lot of researches I decided to switch to Pentax.
I just got my K5 loved it, the kit 18-55mm WR lens amazes me in a lot of situations when I shoot landscapes, but sometimes it is just not long and fast enough to capture my 5 year old daughter's wonderful moments.
Any suggestions for a decent lens to cover that purpose? Thank you!
12-23-2011, 03:17 PM   #2
hcc
hcc's Avatar
I like to shoot my children at home and outside, and I tend to use two lenses. At home, I love to use te FA31mm f1.8 because the lens has a superb IQ and is fast. Outdoor, I prefer the DA18-250mm for its flexibility and focal lengh range.
However, sionce yo have already the 18-55mm, you could consider the DA55-300mm for outdoor as a complement of the it lens, and you could consider a fast 50mm (like the FA50mm f1.4) for indoor.
Hope that the comments may help... and Merry Xmas.
12-23-2011, 03:20 PM   #3
That is what i have been thinking too, a good prime and a good zoom. Thank you very much! And Merry Christmas to you too!!
12-23-2011, 03:30 PM   #4
+1 on the 55-300, although i think you'd be better off with something wider for indoors like the DA-L 35mm f/2.4, since 50 feels a tad tight to me for indoorsy shots
12-23-2011, 03:41 PM   #5
psychdoc's Avatar
Try renting the lenses from cameralensrentals.com first. You can try different lenses for a reasonable price.
12-23-2011, 03:42 PM   #6
If you have the money the fa31 and the da50-135/2.8 or the 60-250/4
12-23-2011, 03:48 PM   #7
QuoteOriginally posted by kenafein Quote
+1 on this suggestion. I use the 60-250 for all such activities and it is superb.
12-23-2011, 04:42 PM   #8
QuoteOriginally posted by GaryH Quote
The 60-250 is too much over my budget for now, I am considering either sigma 70-200 or tamron 70-200, i think they both decent zooms, for prime a 50/1.4 is probably what I will go for.
Thanks guys for your comments.
12-23-2011, 05:46 PM   #9
QuoteOriginally posted by CTHUSA Quote
Both of those are good choices also. The Tamron is probably the best for the money.
12-23-2011, 06:19 PM   #10
Docrwm's Avatar
Welcome aboard!
I have to recommend the DA 55-300 (or even the DAL 55-300 as they are optically identical, the L version comes with plastic mount, no quick shift for manual focus, and no hood but is significantly less expensive) when on a budget. It's rated very high considering its a "kit lens" and for good reason. If budget was less of a concern I'd recommend one of the f2.8 zooms out there. For indoors with lower light either the DA35/2.4 of the FA50/1.4 are excellent choices. I'm finding the 50 great for outside and sports inside but not so great for candids inside with the family as its a bit longish for that and the 35 is more useful. Coupled with your 18-55 the 55-300 and a lower f prime gives you a great kit.
12-23-2011, 10:36 PM   #11
MSM
MSM's Avatar
I am new to Pentax.
Welcome. You may want to consider the Da 18-135. It is a nice lens particularly for your children at least outdoors. I have two little ones myself. Although it seems great to pick a longer zoom like the 60-250 or the 55-300, the issue becomes the wide end of the lens. It never fails with children. You put on a short zoom and they are running away. You switch to a longer zoom and they are 3 feet away. Perhaps your children only run parallel to the sensor plane. Mine just know intuitively which lens I have mounted and take 'appropriate' evasive actions. I have always found that any zoom (which is most) that starts or ends around 50 mm equals many lost shots. Of course, YMMV. Also I would add that the idea of chasing a child with a 60-250 is crazy heavy (and expensive). The 18-250 is also a good cheaper alternative. But, I love the speed of the AF of the 18-135 mm really nice for a 5 yo. It is not a fast lens re: aperture but you have a great camera with high ISO capabilities. You could get a DA 35 mm/2.4. I love fast lenses as much as the next person but with active small children the shallow depth of field equals missed shots. Just a few thoughts from a dad who has tried/failed with the18-55, 55-300, 50-200 combos (Can*n 70-200, 18-55).
12-24-2011, 12:03 AM   #12
wasser's Avatar
I personally use a combination of DA 15mm, FA 31mm, DA 40mm, FA77mm for all around shooting with the family (indoors and out, depending on the need). If I'm at a recital or some performance I usually use my Pentax K 135mm f2.5. And then for sports I use my 55-300mm.
Since you're after speed and longer focal length, I'd suggest the Tamron 28-75mm f2.8, or either the DA 70mm f2.4 or FA 77mm f1.8.
12-24-2011, 11:43 AM   #13
MSM
MSM's Avatar
@Wasser: I like the Tamron too. Fast and great range. Sometimes I wanted wider and a little longer though.
12-24-2011, 02:27 PM   #14
RioRico's Avatar
I have a zillion lenses, put together into various sub-kits and mini-kits. One kit I *don't * use is my 18-55 plus 60-300 (or 70-210) pairing, because I shoot a lot between 35-70, and I detest swapping lenses around 55mm. So my basic lens is the DA18-250, with the FA50/1.4 for action|dimness. That superzoom and its Tamron twin are just the most flexible lenses around. But are no longer in production, though widely available used.
Of new lenses, I'll recommend the DA18-135 as being the most useful range -- except for sports. That's where the DA55-300 would excel, with one of the 70-200s as a backup option. Or maybe not! When my grandkids reach action-sports age, I'll probably whip out my trusty FA100-300 (silver). This can likely be found for around US$100. IMHO it's the best deal in AF long tele zooms.
So, my formal recommendations:
* FA50/1.4 for low light and fairly close action
* DA18-135 for most fairly close activities
* FA100-300/4.7-5.8 for daylight sports
k-mount, lens, lenses, lot, pentax, pentax lens, slr lens
People Children B/W SandraDee Post Your Photos! 5 11-26-2011 07:34 PM
Stealing Children Rupert General Talk 10 02-25-2010 03:18 PM
Children's Jewelry graphicgr8s General Talk 48 01-12-2010 09:27 PM
Early morning activities. Simon23 Post Your Photos! 5 02-10-2009 08:05 AM
Cave activities Matjazz Post Your Photos! 9 04-06-2008 06:12 AM
All times are GMT -7. The time now is 11:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
