01-02-2012, 08:26 AM   #16
telly0050's Avatar
i have another question, is there any optical difference between the M and the A version?
in lens review section, the M version receives more and higher rating than the A.
just checking out.
01-02-2012, 08:37 AM   #17
JVi
QuoteOriginally posted by telly0050 Quote
just checking out.
I had the A version only for about 25 years and just sold it very recently. It worked well. My only experience in that range is between the M and A 50 1.4's. I kept the A because of the semi-automation of the A. The M was optically the same as were the results. I have had four Tak's of 50 1.4 (3 of them the 8 element types) and only one of them came close (but not quite as "good") to the M or A versions in my static testing results (the 8 element is over-rated IMHO and the 7 element version's yellowing is annoying).
You will love your lens; clear and a workhorse.
01-02-2012, 08:58 AM   #18
telly0050's Avatar
thanks jvi
so i think spending an extra 40 bucks for the A to speed up workflow is worth it.
01-02-2012, 09:25 AM   #19
baro-nite's Avatar
just checking out.
According to info on Stan's Pentax Photography and Pentax Normal Prime Lenses they are optically identical. Coatings may be slightly different. Ratings in the review section are not systematic, and I suspect the M gets a boost because the typical cost is so low its perceived value gets a boost.
01-02-2012, 09:41 AM   #20
thanks jvi
I have both (soon). The M was a bonus in an Ebay lot and I'll have to decide which one to keep. Speeding up workflow isn't really the reason I like the A though. I like it because it records aperture values (interesting when evaluating what worked/didn't) and you can shoot in Av mode. It's also nice because you don't accidentally forget to hit the green button...
But I think this is an excellent choice. It's inexpensive and really, really good.
24-70mm, 50mm, da, f2.4, f2.8, k-mount, k5, kit, macro, pentax lens, situation, slr lens
Zoom vs Prime eccs19 Pentax SLR Lens Discussion 111 08-29-2011 02:53 PM
Easy step-by-step test for front/back focusing? Javaslinger Troubleshooting and Beginner Help 3 01-11-2011 12:51 PM
prime vs. zoom a_brooke2006 Pentax SLR Lens Discussion 23 10-23-2010 01:59 PM
General rule for step-up step-down rings? uchinakuri Pentax SLR Lens Discussion 2 06-18-2010 09:54 PM
Should I add a prime or a zoom? Which one? Buschmaster Pentax SLR Lens Discussion 5 01-02-2010 08:27 PM
All times are GMT -7. The time now is 09:52 PM. | See also: NikonForums.com, part of our network of photo forums!
