Originally posted by Jennifer Azzopardi I am relatively a beginner and in need of a Pentax lens that is good to use indoors in poor light conditions. Any suggestions on what kind of lens I need and what specs?
Are you willing to manually focus?
Are you willing to use a prime lens (one without the capacity to zoom)?
If the answer to both questions is 'No', then buy a f2.8 zoom (several mentioned here)
If the answer to both questions is 'Yes', then buy an old manual focus prime lens. (28mm f2.8? 35mm f2? 50mm f1.7? these can be had well under $100)
If the answer to the second is yes, then consider an autofocus lens. The Pentax DA 35mm f2.4 is relatively cheap for a lens (~$180), and is relatively standard focal length. Other good, cheap options are older and must be bought new (Pentax-F 28mm f2.8 (~$200), Pentax-F 50mm f1.7 (~$200). If cheap isn't necessary, there are lots of good new lenses to choose from.
If you are thinking about buying a prime lens, try using some tape to lock your kits lens to a single focal length and see if it works for you.
