The New Kit Lens for the K5 and Newer;
Pentax is losing ground in the DSLR world; build a camera system around two new lenses. 14mm-80mm f/2.2 WR all metal and rubber no plastic, and a 80mm-250mm f/3.2 WR. APS-c only no FF. Make it fit the ASP-c sensor.
The 14-80 f/2.2 would be the new KIT lens I know it is going to raise the cost of the kit, but people would be buying them so fast that the factory will have to go on line 24/7 and hire more employees for QC.
That is my next point the QC must be there 100% of the time and get rid of all the SDM problems and other things before they are released to the public. That will make people want to invest in the K5 and newer cameras as long as they can trust Pentax / Ricoh.
They have to put the time and money into building a top notch lens, if it calls for six ED lenses put them in.
The new lens should not know what the word soft means, only Sharp from edge to edge and corner to corner with 0.0% ghosting and flare throughout the entire range of 14-80mm And no CA control it 99.9%. We need a new formula for coating the lenses the old just isn’t good enough with Digital Cameras.
If Canon and Nikon can do it so can Pentax!. We should not give way to the mirror-less cameras they just don’t get the job done. Go DSLR!
The weather seals need to compliment the K5, as the K5 has so much to offer but the glass is hiding somewhere.
Pentax need to do whatever it takes to put their name at the top of the pile.
Well if you want to add to this lens and camera combo please add to it.
