01-06-2012, 06:26 PM   #1
is the 28-80mm power zoom compatible with DSLRs
Pentax-FA 28-80mm F3.5-4.7 Reviews - FA Zoom Lenses - Pentax Lens Reviews & Lens Database
Is the 28-80mm Powerzoom compatible with DSLRs, in that can you change the focal length? It appears that the zoom doesn't work on my K-x, or my film era zx-30. The zoom focal length is stuck at 50mm.
- Shel
01-06-2012, 07:19 PM   #2
blackcloudbrew's Avatar
Apparently not. Check this thread out. Oh, it will work on the K5.
https://www.pentaxforums.com/forums/pentax-lens-articles/49443-pentax-power-zoom-explained.html
It's a nice lens, I have one and I like it a lot on my K5 and K20d. Really though the fun PZ functions (focus tracking, star zoom, and one other one) wont work on any DSLR only film bodies, but the remember last zoom and power zoom will function on the indicated DSLR bodies in the thread.
I don't understand why you can't change the focal length. The lens has a manual zoom mode (move the zoom ring towards the camera) that should work regardless.
01-06-2012, 07:48 PM   #3
I've been using the FA 28-80mm lense on the Pentax K2000. It's a similar lense, not quite the same one but I did run into one issue:
On occasion, the zoom does tend to lock up. That is, sometimes it gets stuck in the range from 80-50mm. There is apparently an incompatibility with the zoom mechanism on this lense and the AF of newer DSLR's such as the K2000. The issue is intermitted and does not always happen. The only solution I have found is to uncupple the lense from the DSLR body and manually twist the zoom back and forth from 80mm to 28mm, and back again a few times. This gets the zoom un-stuck.
I don't think the FA-J version of the 28-80mm zoom would share this flaw, because it was mechanically optimized for early DSLR's such as K-*ist even though I'm told it's optically identical. For that reason I'm going to buy an FA-J fairly soon. You might consider the same.
01-06-2012, 09:06 PM   #4
QuoteOriginally posted by blackcloudbrew Quote
Thanks! figured it out.
28-80mm, dslrs, k-mount, length, lens, pentax lens, reviews, slr lens
missing switch on 28-80mm power zoom paulmboat Troubleshooting and Beginner Help 7 01-01-2012 02:13 PM
How compatible are Pentax DSLRs with old lenses? stainsor Pentax SLR Lens Discussion 16 11-02-2011 07:27 AM
TAMRON 28-80mm f/3.5-5.6 77D - is this compatible with my K-X? newbie here SweetSherri Pentax SLR Lens Discussion 4 04-03-2011 03:53 PM
Are the dedicated Metz flashes fully compatible with current Pentax DSLRs? Eric Seavey Flashes, Lighting, and Studio 6 02-08-2011 06:23 PM
For Sale - Sold: PZ-70 and FA 28-80mm power zoom lens Nick Siebers Sold Items 6 12-03-2009 09:36 PM
All times are GMT -7. The time now is 08:15 AM. | See also: NikonForums.com, part of our network of photo forums!
