01-07-2012, 09:01 PM   #31
manacho2005's Avatar
Pretty sure they were all the same. If you were using a Takumar or something other than a Pentax-M lens then maybe, but otherwise only the needle moved up and down.
Now I want to dig that thing up and check if it was broken. I had an m50 1.7 and an albinar 135 f2.8 and it would stop-down as it metered when I would change the aperture....hmmmm Oh well, once Kodak goes under, unfortunately it may soon be irrelevant. Unless fuji film stays around.
01-08-2012, 09:55 AM   #32
Marc Sabatella's Avatar
So, you're saying the viewfinder darkened as you changed aperture, to the point where focusing was essentially impossible past f/8 or so? I'm guess that's not the case. You saw the metering change as you moved the aperture lever, but that's not because the lens was actually stopping down - it's because the camera read the aperture ring. That's what current cameras no longer have the hardware to do.
A couple other misconceptions to clear up:
The two pictures you took might jave had the same exposure and FOV, but the DOF was *entirely* different between them, because of the difference in actual aperture.
Also, when shooting in M mide, you don't need to change exposure with every shot - just whenever the light changes enough to affect exposure significantly enough to be worth adjusting for. If you shot with a K100D, you should realize this isn't *that* often.
01-08-2012, 10:02 AM   #33
My viewfinder would darken, so now I'm wondering if my coupler was broken... All my shots were outside, and I never really went above f11 so it wasn't that bad. It was my first camera, so I never knew it was wrong, but since I've had my P3 and k10....epiphany
50mm, focus, k-mount, lens, light, pentax lens, picture, shot, slr lens, stock
Riddle me this!!! (Riddle thread, try to stump someone) KxBlaze General Talk 19 05-27-2017 04:12 AM
I have a stock and 50mm lenses.. do I need 35mm and lower? SRG01 Pentax SLR Lens Discussion 11 06-19-2011 10:39 PM
35/50mm fixed AF lens-what price 2nd hand dinneenp Pentax SLR Lens Discussion 7 03-19-2010 08:58 PM
Riddle me this Batman... MD Optofonik Pentax SLR Lens Discussion 14 02-13-2010 05:12 AM
DA* 16-50mm out of stock? lurchlarson Pentax News and Rumors 53 01-30-2010 10:40 AM
All times are GMT -7. The time now is 02:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
