01-11-2012, 06:52 PM   #1
Rokinon 135 f2.8 lens with Pentax Kx
Hello folks,
I am new to this forum. I am a recent entrant to the DSLR club and still taking baby steps. I bought a used lens off ebay, a Rokinon 135 mm f2.8 lens with a k-mount to be used with a Pentax Kx. I have been having trouble mounting it. However I play around with it, it just won't fit right. Any knowledge or pointers about this lens would be greatly appreciated.
Thank you for your time.
01-11-2012, 06:55 PM   #2
ducdao's Avatar
QuoteOriginally posted by wildbaron1234 Quote
Hello folks,
Welcome to the forum. Can you post a picture showing a close up of the mount?
01-12-2012, 04:07 AM   #3
TZH
TZH's Avatar
Ebay seller might failed to verify the mount , I see this all the time.
The best way is to upload a photo.
01-12-2012, 05:13 AM   #4
JohnBee's Avatar
Hello folks,
I was under the impression that the Rokinon 135 came in Minolta mount?
01-12-2012, 06:16 AM   #5
RioRico's Avatar
QuoteOriginally posted by JohnBee Quote
Mine (serial # 141658) is in PK-M mount. The mount is not labeled. If Ricoh made Rokinon sold different versions, we'd indeed need to see a picture of the mount to tell just which it is.
EDIT: Correction in italics.
01-12-2012, 06:33 AM   #6
boriscleto's Avatar
Mine (serial # 141658) is in PK-M mount. The mount is not labeled. If Ricoh made different versions, we'd indeed need to see a picture of the mount to tell just which it is.
Rokinon, not Rikenon. Rokinon was a reseller, just like Vivitar. They sold lenses in FD, F, and MD mounts for sure, not sure about PK. The only one I've seen listed is a 500mm mirror. The newer Rokinons are just rebadged Samyangs.
01-12-2012, 06:44 AM   #7
RioRico's Avatar
QuoteOriginally posted by boriscleto Quote
You're right, I mis-spoke (early morning confusion), and it's fixed. Yes, Rokinon (old days, like pre-AF) was the badge on lenses with Pentax mounts. My two Rokinons are 28/2.8 and 135/2.8, both PK-M mount.
PS: I hate the Rokinon name, just because it's so confusable with Rikenon. Seems like a cheap rip-off name, like photo gear labeled Pantex or Nokon or Cannon, or a Fendar guitar. [/me grumbles & whines]
01-12-2012, 06:57 AM   #8
[IMG]C:\Documents and Settings\n546137\My Documents\Downloads\photo.jpg[/IMG]
Thanks for the info folks. I bought it with the impression that it was an RK mount, which would fit a Kx. Anyway, here is a photo of the lens. I have marked the mount flanges. Please let me know what you guys think.
Thank you.
01-12-2012, 07:04 AM   #9
iF YOU ARE HAVING TROUBLE GETTING IT ON THOUGH...DO NOT FORCE IT!!
I had a small panic last weekend from an older Focal MC lens that had a Ricoh pin...well not really but it had a pin that once i did get it on...well a hacksaw got involved. If it does not fit do not force it. Big lesson learned for me.
01-12-2012, 07:21 AM   #10
QuoteOriginally posted by martyd14 Quote
Hacksaw involved? We must see aftermath pictures!
01-12-2012, 07:43 AM   #11
Man i wish i had pics of it but after the 2 hours of trying to twist, disassemble and finally cut this lens in half and then having it finally just pop off with a yank in the right direction...well that lens got tossed quick. this thing was solid metal and was made like a tank. wish it would have fit! No harm to the K-x at least
01-12-2012, 07:44 AM   #12
bluestringer's Avatar
The image is not showing. I have a Kalimar lens PK-R mount that would not fit because the flange that protects the aperture lever was too big. I removed the 2 small screws holding the flange and removed it. Works fine now. Don't know if that is your problem or not. If it is a PK mount, that would be something to look at. Also if it has the Ricoh pin, make sure to remove it before mounting.
01-12-2012, 08:16 AM   #13
I am hoping this works
01-12-2012, 08:26 AM   #14
ducdao's Avatar
THis is definitely not a K-mount lens. Looks like Canon or something.
There seem to have two aperture levers, K-mount only has 1.
01-12-2012, 08:44 AM - 1 Like   #15
boriscleto's Avatar
Not a Canon FD, it's an Olympus OM mount. Identifiable by the lens release and stop down buttons opposite each other.
f2.8, f2.8 lens, k-mount, kx, lens, lens with pentax, pentax, pentax lens, rokinon, slr lens
Travel Lens: Pentax 18-135 vs. Tamron 18-250 darenka Pentax SLR Lens Discussion 15 09-28-2011 09:16 PM
SMC Pentax-F 135 1:2.8 Lens cleaning Lenny5896 Troubleshooting and Beginner Help 4 08-19-2011 02:34 PM
Rokinon SMC 35-135 mm Lens Vasyl Pentax SLR Lens Discussion 3 01-02-2011 04:10 PM
Question on Rokinon 500mm mirror lens Gerrys Troubleshooting and Beginner Help 5 10-17-2010 05:13 PM
ROKINON 85MM F1.4 LENS NEBULA_ONE Pentax SLR Lens Discussion 7 03-12-2010 10:51 AM
All times are GMT -7. The time now is 07:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
