Originally posted by hinman Other than the infinity focus, do you find similar optics and performance on the two lens that you have in M42 and M39?
On the M39 version, I had no problem with infinity focus, just sticky focus. IMHO the M42 version performs a bit bitter -- newer coatings maybe? Mine were definitely different eras -- the M39 was #N6328612 (1963?) and the M42 is #7372643 (1973?). My scale is only accurate to 10g intervals; my M39 weighed 60g, the M42 is 70g (closest approximation). So their builds are different. I do prefer the M42.
Quote: I am also looking for a better M42 to K adapter other than the genuine adapter.
I just use a cheap Bower adapter, remove the screw and clip SO I DON'T GO APESH!T! and use a rear lens cap to wrench the adapter on the lens. No problem.
___________________________________________________
INFINITY FOCUS: I've had no infinity focus problems with either version. I do hear complaints about not reaching infinity with the M39-->M42-->PK adapter chain. There is a pretty easy solution: MOD THE M42-PK ADAPTER!
I found this whilst fitting Exakta-mount lenses to PK. Exakta register is about 0.8mm shorter than PK. But I find that grinding about 0.6mm from the adapter lets the lens seat close enough for infinity. With Exakta, remove and save the index screw, then glue a cheapest M39-M42 ring around the bayonet. While the contact cement dries, tape a piece of coarse sandpaper to a very flat hard surface like a ceramic tile. Use a block of wood or rubber as a grip to press down on the adapter, to grind away at the narrow flange. Test occasionally for infinity focus and stop grinding when it's achieved. Don't grind too thin; at least 0.2mm of the narrow flange must be left, or the adapter won't seat in the mount.
A thinned adapter should work on any narrow-base M39 or M42 lens that doesn't reach infinity. And of course the thinned adapter can be used with many lenses. And for close work, just use a stock (unmodified) adapter, or even a wide-flange no-infinity-focus (NIF) adapter. My ultralight minikit now contains (at times) Exakta-mount 40mm and 50mm lenses (with a 105mm nearby) and the I-50-2; thinned, unthinned, and NIF adapters; and a couple thin M42 macro tube sections. Great flexibility there!
