Originally posted by bobmaxja DA L a lot sharper. Anyway color can be adjusted in PP or in camera
Perhaps at 35mm. But here you're comparing a focal range where the DA 18-55 is at its strongest with a focal range at which the 35-105 is probably weaker. At 55mm I would venture to guess that the F 35-105 is sharper, perhaps considerably sharper.
And while color can be adjusted, there are limits to what you can achieve. Nothing beats a lens with excellent, distinctive color rendition.
Originally posted by reivax I wonder if there are any tips to increase the sharpness on the 35-105
A hood might help a little bit with the contrast. The main thing is to use a tripod, stop down the lens, and shoot in the middle of the zoom's range. Most of these older lenses are not always very sharp at the wide and long ends of the zoom. That's perhaps one of the reasons the older A version of the 35-105 is so well liked: it has more consistency across its focal range than a lot of the older zoom lenses with comparable range.
