01-14-2012, 02:51 PM   #1
Takumar 35mm F2 - Infinity adjust:
Anybody accomplished an infinity adjustment on this lens - Takumar 35mm F2 49mm edition?
I removed the bezel to use the "normal" Takumar infinity adjust procedure and discovered a different mechanical construction. The front lens is secured only by the bezel and may be removed with the bezel!
No! this is not just because the securing screws are missing - it doesn't have any means of using such screws.
Anybody had experience with this lens - will much appreciate you sharing that with me!
01-16-2012, 09:13 AM   #2
Maybe you should post this same question here: https://www.pentaxforums.com/forums/lens-clubs/31601-takumar-club-631.html
I've only adjusted infinity focus on an F 70-210, so I can't help you here...
01-18-2012, 04:49 PM   #3
QuoteOriginally posted by theunartist Quote
Figured it out by myself - the adjustment is basically the same as for the other Tak's - just a difference with the front element group. Adjustment is tricky because you can easily jam up the blades (which I did do until I figured out what was happening.
This lens (Takumar 35mm F2, non SMC) is a wonderful lens and I'm very happy to have it focusing correctly - it will get lots of use.
35mm f2 infinity, bezel, f2, infinity, k-mount, lens, pentax lens, screws, slr lens, takumar
500/4.5 SMC Takumar infinity focus issues? d.bradley Pentax SLR Lens Discussion 19 02-11-2017 02:45 PM
Asahi Super-Takumar 1:1.8/55mm Lens won't focus to infinity bingostew Pentax SLR Lens Discussion 15 10-25-2012 08:19 AM
K10D GX10 CCD Position Adjust (AF adjust) kevbirder Pentax DSLR Discussion 10 09-22-2011 02:35 PM
Infinity issue with Super Takumar 50/1.4 shutterdrone Pentax SLR Lens Discussion 3 04-28-2008 04:50 PM
All times are GMT -7. The time now is 05:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
