01-18-2012, 09:14 AM   #1
Pentax 50mm 1.7 shaking
Hi.
Just got a 5mm 1.7 second hand and it is very nice to have 1/60s shutterspeed indoors.
The problem is when I shake the lens (when off-camera) I can hear it rattling; like something is loose inside. Is that something to worry about?
Regards
01-18-2012, 09:21 AM   #2
JohnBee's Avatar
Sometimes the aperture lever or mechanism can be loose inside.
Did you try pushing and holding the lever(to add tension) to see if that changes anything?
01-18-2012, 09:37 AM   #3
I have tensioned the lever and shake but it still sounds like that. :/
Do your 50mm rattle?
01-18-2012, 09:42 AM   #4
JinDesu's Avatar
I have to check when I get home, but I do believe my M50 1.7 rattles. I also searched on this forum before when that happened, and I believe it's a common thing. As long as it's rattling off camera though - on camera, would be a little weird.
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/85546-does-you...-7-rattle.html
01-18-2012, 09:51 AM   #5
JohnBee's Avatar
QuoteOriginally posted by striker_ Quote
I'll check
01-18-2012, 09:55 AM   #6
JohnBee's Avatar
Okay I checked two of my own copies(both A/1.7) and they are rock solid(no noises). Though one of the aperture rings makes a slight noise when I shake it, however if I put my finger on it, its quiet. Other than that, everything is nice and tight on both.
BTW. what version of 50/1.7 do you have? A or M?
01-18-2012, 10:51 AM   #7
My copy of the Pentax M 50/1.7 makes a high pitched sound when I shake it. It's worked pristinely up to this point, so I don't mess with it - I assume it's something in the aperture, but the aperture is nice and tight and responsive.
01-18-2012, 11:18 AM   #8
JohnBee's Avatar
QuoteOriginally posted by icywindow Quote
If you remove the mount flange(held by three small screws) you will might find the culprit. There's a spring and mechanism in their and I think they can get worn and loose over time.
Then again.. I agree with what you said too.
If it works, then it likely isn't a serious issue.
Enjoy your 50/1.7 btw. That is one heck of a sharp lens.
JohnB
01-19-2012, 09:22 AM   #9
Mine (M50) doesnt have high pitch sound. Just like something is loose inside.
Ive tried unscrew it but Pentax has screwed it so damn hard. Its unable to turn. :/
When I turn the aperture it clicks good but the click between f/2 (I suppose (no mark)) and f/1.7 seem a little harder and not as snappy as the other apertures.
It takes photos good so I dont think I'll worry too much about it. Btw I have a Pentax A 50mm 1.7 on the way from UK. Hope the A-setting is useful.
01-19-2012, 04:18 PM   #10
Ex Finn.'s Avatar
My A 50 1.7 does, always has, since 1985 or so. It has stayed most of its life in the "A" setting.
01-19-2012, 04:29 PM   #11
fccwpe's Avatar
Mine had the same issue and I used a pencil with an eraser to tighten the ring where "ASAHI OPT. ...." is printed. Worked like a charm. May want to give it a shot.
01-19-2012, 07:46 PM   #12
kaiserz's Avatar
Mine does too..
01-20-2012, 07:42 AM   #13
I just got mine (50 M 1.7), it's like new, and it does the same high pitch rattling when I shake it, maybe it is common thing. With it I got 35 3.5 k, and it does the same thing, just little lower in pitch.
01-21-2012, 12:10 PM   #14
My M 50/1.7 has always (since new in 1982) rattled a little when off camera. My A 50/1.7 does not rattle, despite having inferior build compared to the M. I did a quick survey of my lenses and most rattled a little. One was particularly silent...my Russian Jupiter-9. That is not surprising since it has a preset aperture mechanism and much less to rattle.
01-21-2012, 01:43 PM   #15
Thanks for all the replies. Now the worryness are gone.
k-mount, pentax 50mm, pentax lens, slr lens
Shaking problem in liveview on a pentax k-x commanderWhatNow Troubleshooting and Beginner Help 8 05-29-2011 07:20 AM
Shaking by shutter movement saltshakalickalime Troubleshooting and Beginner Help 17 02-28-2011 09:57 AM
pentax kx shaking noise loud loud ? ritualart Troubleshooting and Beginner Help 15 08-12-2010 08:41 AM
Live view problem with K20d ? shaking a lot! TanGU Pentax DSLR Discussion 12 07-23-2010 08:40 AM
SR And Shaking Shub Troubleshooting and Beginner Help 4 03-21-2010 04:10 PM
All times are GMT -7. The time now is 04:49 AM. | See also: NikonForums.com, part of our network of photo forums!
