Originally posted by newarts
I wouldn't bother to do it again unless I had a superb FD lens to start with.
I have had ones that were a breeze and took very little time while I have had others that were a nightmare. One in particular that was a nightmare was my fault though. I must have mis-measured somewhere. I used a donor mount and thought that I might actually be able to rig camera control of the aperture but I had to take substantially more off the mount that expected. The hard part was taking more and more off the mount while still maintaining even thickness. I had to thin a couple of mm more than I expected if I recall right and wiped out the hole for the aperture spring retaining screw.
I have kind of switched to the idea of making adapters to see how that works though. I have miranda?, canon, minolta and nikon cameras (junkers I got really cheap in a lot). I'm thinking something along the lines of silver soldering the mounts off the camera to an m42 adapter or something along those lines to get a minimum thickness glassless adapter. Of course with canon, minolta etc I would only get macro but it will be interesting to see what I get with nikon. I suppose I'll see if there is already one made first of course before starting one. If the canon one with the teleconverter goes good I may try other mounts from teleconverters, which in theory could potentially have good glass and not loose too much image quality. The biggest thing standing in the way, is that a 1.4x would be ideal and they tend to be expensive to go hacking up.
In the end though, if adapting doesn't work out well, I will probably continue to convert the lenses I have. Sure, sometimes its a pain but often its not too bad. It seems what parts you have available can have quite an impact on how hard it is (in particular what you have to make shims with). As far as new purchases though, I defiantly think I will stick to better lenses. Sometimes obsolete mounts can be quite a bit cheaper compared to k mount though.
