12-29-2007, 10:51 AM   #1
Difference between a macro and "regular lens"
This is going to be a naive question: I recently picked up some older manual lens and one is a 50 mm 1:4 Macro lens. I just got around with playing with it and it seems to be pretty good for both close up and mid distance (10's of Meters or yards). I see the photos of lots of other 50's as well and most of them are not macros. In this case is this macro designed to do only close up's (dial goes down to 0.234 M) or does it sacrifice something when not used as a macro?
What is the differences between lens of same aperature size designed for macro and not?
12-29-2007, 11:11 AM   #2
mer
The differences between a 50mm macro and a regular 50mm are :
1) The macro is corrected for flatness of field and generally have high sharpness / can resolve high resolution .
2) Lenses , that do not employ a floating element , are only optimized for only one magnification . Most regular lenses are optimized for infity or close to infinity , most macros are optimized for 1:10~ magnification . That means tha macro lenses dont perform as good at infinity as they do in high magnifications . But because most macro lenses are generally very good they perform quite good at infinity as well .
3) Macro lenses have enough extension into them to use them up to 1:2 or 1:1 magnification , without having to add extension tubes
01-01-2008, 02:33 AM   #3
Mechan1k's Avatar
I can show the difference in 2 images later when i upload them.
Although taken with a Tamron 90mm SP Macro though ... one is a 1:1 macro shot and the other is a "normal" shot.
Macro of Hibiscus stamen (handheld & winday day)
Normal shot of the actual hibiscus the macro was taken from.
Then if you really want to have a close look ... you could then get a 100% crop taken from either ... it'd be even closer again (the above image is not cropped at all ... jpeg straight from the camera.)
01-01-2008, 04:40 AM   #4
JCSullivan's Avatar
If I understand it correctly the question is: What's the difference between a 50mm and a 50mm ~ Macro.
In my opinion (I have both) - dick-all.
close, k-mount, lens, macro, pentax lens, slr lens
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 35 02-10-2016 09:10 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
What difference does "D-Range 200%" really make? amateur6 Pentax DSLR Discussion 28 05-06-2008 09:22 AM
What is difference "APO" and "ED" glass in a lens? kathyk Pentax SLR Lens Discussion 4 03-06-2008 08:59 AM
All times are GMT -7. The time now is 09:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
