02-14-2012, 09:47 PM   #31
RioRico's Avatar
QuoteOriginally posted by mikeSF Quote
3) DA10-17, more of a special effect. far wider than the rectilinear 10-20, in fact i think 10mm on the Sigma covers about as much scene as 17mm on the fisheye,
Yup. The Pentax fisheye at 10mm has a rated 180 degree view although I measure it closer to 170 degrees on my K20D, whose sensor is slightly smaller than nominal APS-C. At the long end (17mm) it's rated at 100 degrees. The Sigma rectilinear goes from 74-113 degrees on nominal APS-C, or 70-109 degrees on my K20D.
The fisheye may not be exactly 10-17mm focal length. Other lenses don't measure precisely perfect -- there's some tolerance in the specs. Lenses are only human, eh?
k-mount, length, pentax lens, slr lens, wa
The K-5.......the right choice for me! RIDE Pentax K-5 20 08-02-2011 09:22 PM
Which would be a better choice for the K-r: DA 35 2.4 or A 50 1.7? Taobat Pentax K-r 18 05-25-2011 10:25 PM
Misc The Choice KarenH Post Your Photos! 19 11-15-2010 02:08 PM
MF choice icywarm Pentax Medium Format 5 05-24-2010 08:00 AM
Help with the choice of a scanner Rense Pentax Medium Format 22 04-27-2010 10:55 AM
All times are GMT -7. The time now is 04:45 PM. | See also: NikonForums.com, part of our network of photo forums!
