02-03-2012, 03:34 AM   #1
Cleaning 55/f1.8
I am cleaning a Takumar 55mm. The problem I have come across is that there is a bit of haze between the the inner rear lenses.
I have removed all of the bonding stuff with acetone, but the inner lenses still won't come apart. Any ideas on how to seperate the glass would be greatly appreciated.
02-03-2012, 06:34 AM   #2
esdy_11192's Avatar
I have the same problem with a lens from an Italian fixed lens RF. The glass elements on the photo are actually cemented together. My problem is that I have a lot of fungus on that cement (the fungus is actually eating cement). As I searched the internet I came across a little bit of info. The major problem would be re-cementing those glass parts once they are cleaned. But I don't have an clever idea how to decement them.
02-03-2012, 07:09 AM   #3
ismaelg's Avatar
Sorry I can't be of any help, but assuming you can take them apart, which I haven't found a way to do, as far as I know there is no way to properly cement them back together doing it yourself. From what I understand, cementing requires precise micro-thickness controlled application and alignment, not to mention finding the appropriate cement in the first place.
Good luck and let us know if you find a way......
Thanks,
02-03-2012, 08:16 AM   #4
monochrome's Avatar
The glue was once Canada Balsam. Now they use an epoxy compound and UV cure it.
02-03-2012, 08:50 PM   #5
Thanks all for the insite. I may just keep a lookout for another lens for parts.
k-mount, lenses, pentax lens, slr lens
Cleaning help chailli_d Photographic Technique 3 12-30-2011 08:51 AM
FA 50 f/1.7 cleaning Designosophy Pentax SLR Lens Discussion 2 08-31-2011 06:08 AM
Cleaning ? mom2mny Troubleshooting and Beginner Help 3 05-03-2011 09:32 AM
Camera Cleaning thrillerb Troubleshooting and Beginner Help 10 04-13-2010 08:34 AM
Sensor cleaning. Modus Operandi Troubleshooting and Beginner Help 17 03-12-2010 04:48 PM
All times are GMT -7. The time now is 01:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
