Originally posted by sharepointalex Would also like to confirm with you guys the correct procedure for using these older MF lenses on new Pentax DSLRs:
3. Press the green button to allow camera to select the correct shutter speed
When you've got the green button pressed,
you'll have to adjust the shutter speed with the wheel
until the camera confirms correct exposure.
So the camera allows you to select the correct shutter speed.
This assumes you've done all the other things mentioned above,
like "enabling aperture ring" and setting the FL on start-up.
It all sounds like a pain at first,
but can become instinctive and addictive.
