Originally posted by Classico All look good but I think the Fujinon55 1.8 looks the best. Question about the Chinon Tamioka the pics almost all look around the same F stop for that lens was it a miss label?
Thanks. You are correct, I shot all three photos at f1.4, wide open. Sorry, this is one of those senior moments that I cannot fix. My Chinon Tamioka has the Tamioka label in the front ring, and is really really good. At f4 and f8, it should be really sharper. I just checked the data, all three are wide open. Sorry.
Update, I double check and I indeed turned the aperture ring to 1.4, 4 and 8 and shot. However, the aperture of the Chinon Tamioka remained wide open. The reason, the toggle button was in AUTO. As you know the Tamioks lenses are the opposite, that is, the button is moved towards MAN to select manual, as opposite to others, where the MAN shows when you move the button towards AUTO. I can not repeat the experiment withthe same set up, but will post separate photos of the Chinon Tomioka. I will also post same comparinson with the Chinon Tomioka and the Auto Sears, which I believe is really a true Tomioka.
