02-09-2012, 03:32 PM   #1
vivitar series 1 70-210mm ver 1 vs ver 2?
I was just wondering if anyone knew how the the different versions compare? I already have the version 2 and it is fine. I may have a chance to get the ver 1 cheap. I have found lots of info on specific version, but not much comparing them side by side for image quality. The ver 1 seems to have lesser resolution and contrast than the version 2 (except for contrast at 210mm f8 and in the center only). Of course technical tests like that are not everything. The ver 1 would gain me better macro (1:2.2
vs 1:4 on the ver 2 I already have).
So does anyone know how they compare?
02-09-2012, 03:36 PM   #2
joe.penn's Avatar
QuoteOriginally posted by ripit Quote
If you can get version 1, get it. Version 1 of this lens is the Kiron build with excellent optical qualities and fantastic macro capabilities (3.5 CA w/ 1:2.2 macro ratio) - optically it is as good as the version 3, the 2nd version of the version 3 trumps all others due to speed and the addition of the "A" contacts; the version 1 is also a highly regarded lens; also, version 1 is the only one with a 1:2.2 macro ratio...
02-09-2012, 04:27 PM   #3
Thanks a lot. I appreciate the info. If I can get it cheap enough I'll grab it.
02-09-2012, 05:16 PM   #4
jac
Vivitar Lenses for Pentax: Zoom Lenses - Pentax Lens Review Database
02-09-2012, 05:16 PM   #5
RioRico's Avatar
Version 1 is absolutely brilliant, and a heavy brute at 880g. Using it is good exercise.
02-09-2012, 05:34 PM   #6
joe.penn's Avatar
Crazy good (and fun) when using with extension tubes.
One of the best things I like about this series is the push/pull zoom, as long as it is smooth with your copy you can combine the use of CIF with this lens to near effortlessly (by using slight up/down motion of your thumb on zoom barrel) snap insect(s) macros in flight with precision; a really good well designed lens.
02-09-2012, 05:35 PM   #7
dms
The following is a comparison: of version1,2,3 (MODERN PHOTOGRAPHY results). www.robertstech.com/vivitar.htm
Having used version 2 and 3 extensively and held version 1, version 2 and 3 are much easier to use/carry. Version 1 is historically very important.
Version 3 in my opinion is significantly better than 2--and thus 1 from the modern photo tests.
contrast, k-mount, pentax lens, series 1 70-210mm, slr lens, ver, version, vivitar series, vs
For Sale - Sold: LN Vivitar Series 1 70-210mm f3.5 (Ver.2) for Pentax (US/CAN) hyyz Sold Items 3 04-22-2011 05:41 PM
For Sale - Sold: Vivitar Series 1 (ver. 3) 70-210mm/2.8-4 macro (CONUS) drjaxon Sold Items 2 02-02-2011 01:52 PM
K20D Firmware Ver - Pentax Web Site Ver? ChipB Pentax DSLR Discussion 2 02-23-2010 04:14 PM
For Sale - Sold: Vivitar 90mm f2.8 macro (1:1); vivitar series 1 70-210mm (ver. 3); and Tam 2x jkglogau Sold Items 10 10-06-2009 06:32 PM
For Sale - Sold: vivitar Seeries 1 70-210mm (ver. 3) jkglogau Sold Items 5 09-11-2009 09:34 AM
All times are GMT -7. The time now is 03:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
