02-17-2012, 08:13 PM   #1
lguckert79's Avatar
need to replace my 18-55 kit lens... what should i get??
well i have been doing some looking in on this matter and i have a few options that i found. Well here they are it is a pentax FA 28-70mm f4, another 18-55mm f3.5-5.6 only ill get the WR one, or a sigma 24-70mm f3.5-5.6 to replace my kit i just need some help??
02-17-2012, 08:20 PM   #2
Ikarus's Avatar
QuoteOriginally posted by lguckert79 Quote
I would check the focal lengths of the pictures I've taken with it. If a significant portion is between 18-24mm, this should be an easy choice.
02-17-2012, 11:25 PM   #3
17-50mm, perhaps?
DA* 16-50mm vs. Sigma and Tamron 17-50mm F2.8 Comparison - Introduction - PentaxForums.com
Another choice would be the Tamron 28-75 or an 18-135mm
02-17-2012, 11:40 PM   #4
sterretje's Avatar
Maybe you can explain why 'you need to replace the kit lens' I assume because it's broken, else the option of the WR version does not really make sense.
Only you can judge which 'specs' are relevant. Longer and/or wider and/or faster and/or better IQ.
Good luck in the decision taking
02-18-2012, 04:34 AM   #5
Col
Col's Avatar
Personally I would pick up another used "Kit Lens" first. In the UK they can be had for 29... only slightly dearer than the body cap. Then decide what its limitations have been for you, wide end, tele end, speed or "involvement" and address that area.
02-18-2012, 07:31 AM   #6
lguckert79's Avatar
well i droped my kit lens a while ago and after that all my images are underexposed and i have to overexpose by 5 steps on a sunny day to get a correct exposure so that is why
02-18-2012, 01:12 PM   #7
If you liked your lens before dropping it, and want the WR, then the choice seems obvious. If you wanted more speed, or different zoom range, then of course you should look for something else.
Paul
02-18-2012, 03:13 PM   #8
DaveHolmes's Avatar
DA18-135mm-WR appears to have a slight IQ increase over the 18-55 kit... Might be worth consideration if WR is important...
If IQ and speed are more important than WR then I can vouch for the Tamron 17-50mm-2.8
02-22-2012, 01:43 AM   #9
Hi,
Ive been using tamron 28-75 for quite sometime and decide to sell it due to back focus problem on my K-x (tried on K-R and it works just fine). you have to consider your body too for third party lenses esp. tamron i think...
Used M28 2.8, SMC Takumar 28 3.5 and another 28mm (can't remember)... tak is the sharpest
Landed myself with the da 16-45 last night (after deciding over the tamron 17-50) and from my first pics am loving the sharpness, close focus and perspective of the 16mm....
Consider this lens, you wont regret it...
02-22-2012, 04:49 AM   #10
mickey's Avatar
How about one of the 17-70 lenses by either Pentax or Sigma?
f3.5-5.6, k-mount, kit, pentax lens, slr lens
Best budget or film lens to replace DA 18-55mm kit lens? amc654 Pentax SLR Lens Discussion 27 03-12-2012 02:33 PM
Need new lens to replace my kit :) SRG01 Pentax SLR Lens Discussion 15 11-07-2011 09:36 PM
looking to replace kit lens and bigal1000 Pentax SLR Lens Discussion 5 01-21-2011 06:37 PM
How about a wide angle to replace my kit lens? timstone Pentax SLR Lens Discussion 16 04-27-2010 08:08 AM
Suggestion to replace 18-55 kit lens? sealonsf Pentax SLR Lens Discussion 10 12-15-2009 05:12 PM
All times are GMT -7. The time now is 06:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
