I have only a very limited sample to draw from, but both lenses were aimed at the same market segment and should be a good basis for comparison:
- Pentax-K 55/1.8
- Pentax-M 50/1.7
Both have very similar construction, though the K 55 is obviously larger in diameter and has a beefier feel. The K 55/1.8 traces its lineage to the Super-Takumar of the same focal length/max aperture. The M 50/1.7 was a new design. In actual use, the M 50/1.7 is quicker to focus than the K 55/1.8 (less dampened?). It is also much nicer to have mounted to the compact cameras for which it was designed. Excellent balance. I have been using mine for since the early 1980s mounted to a Ricoh XR7. The M lens also is quite at home on my Pentax KX and Ricoh XR-2s (almost identical dimensions), but the K lens feels sort of clumsy on the XR7 and my Pentax Super Program (duh!).
As for build, I would consider both to be equivalent and among the best available at the time. This may not be the case for other focal lengths.
Optically, the edge goes to the K 55/1.8. Both lenses are sharp and resistant to flare, but the K 55/1.8 has the edge (slightly) for resolution and contrast. I should note, however, that the K 55/1.8 is my best fast 50...and I have a lot of them.
Avoid the M-series lenses as a matter of course? No way! Most are great lenses. Are they inferior to the K-series? It all depends how you define inferior. Are they better than equivalent "A" series? Now there is an entirely different rant
(...loves the K-series lenses, but would generally not pay a premium price for one...with a few exceptions!)
