02-20-2012, 06:55 AM   #1
FA 31 ltd built in FF hood
Does anyone here use an additional hood on th FA 31 Ltd to increace contrast, reduce flare. The built in hood is meant for FF and using an aps-c camera I should be able to find a hood with better coverage.
02-20-2012, 07:33 AM   #2
G_Money's Avatar
I use one of these. eBay
02-20-2012, 10:13 AM   #3
Looks good! But I cannot imagine the way to mount it. Would you be so kind as to deal in detail on the issue.
02-20-2012, 10:34 AM   #4
aleonx3's Avatar
I bought the same hood... it works fine. There are actually two parts of that hood, the top portion with label "for Panasonic FZ18 58mm" will fit into the 31mm filter thread perfectly as it has a straight-up tube. The other part of that hood can be used for a 52mm filter thread lens. Some people use another method to stack up several 58mm filters (without the glass), but this solution looks better.
02-25-2012, 03:40 PM   #5
mikeSF's Avatar
there are other threads on this topic and a few different solutions.
i use a 58->49mm step down ring and a metal 49mm good which works very well and extremely inexpensive.
02-26-2012, 01:36 AM   #6
Heliopan short metal hood, i think... same thread front and back.
There are other cheaper alternatives though.
02-26-2012, 02:07 AM   #7
V10
I stacked 3 empty filter rings on mine and have even attached a short rubber hood at the end without vignetting. It makes the lens looks like it's swallowing 3 whole filters from the side which I find to be a bit funny.
fa, fa 31 ltd, ff, hood, k-mount, ltd, pentax lens, slr lens
Loose Built-in Hood -- Pentax-A 100 F3.5 Stratario Pentax SLR Lens Discussion 10 05-02-2013 12:14 PM
For Sale - Sold: Pentax 645 A 300mm $475 w/ soft case, built-in hood, caps Smolk Sold Items 11 02-24-2012 11:00 AM
FA 77 ltd UV filter or built in hood Franky2step Pentax SLR Lens Discussion 12 08-30-2011 12:27 AM
is the built-in hood an obstacle? noou Pentax SLR Lens Discussion 4 05-23-2011 08:27 AM
Pentax A 70-210mm built-in lens hood question manteiv Pentax SLR Lens Discussion 7 12-20-2009 10:55 PM
All times are GMT -7. The time now is 03:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
