02-22-2012, 04:50 PM   #16
JohnBee's Avatar
QuoteOriginally posted by Sperdynamite Quote
It's pretty bad. I know I could just stop down but is there a way to get rid of this in post? I use it as a portrait lens for weddings and I'm in a lot of back lit situations...
Shoot RAW and use RAW Therapee.
It has very good CA/PF modules(if not the best) and it's free.
There is also a 20 second Photoshop trick you can do to remove CA/PF which is often used for final retouching.
02-22-2012, 04:57 PM   #17
wlachan's Avatar
true Purple Fringing is a digital only issue
From what I remember, there were lots of PF confusing when digital was still young. Then a few websites tried to pin it down with sensor blooming. However, IMHO, this view is too narrow because purple colour fringing isn't caused by sensor blooming alone. Lens CA can be purple in colour too, or green, or red.
02-22-2012, 05:04 PM   #18
Lowell Goudge's Avatar
QuoteOriginally posted by wlachan Quote
Yes lens CA can be purple, but it presents itself differently. True PF from sensor blooming is quite different than CA and is only present at extreme bright to dark transitions. cA is there all the time.
02-22-2012, 06:57 PM   #19
Great explanations - but ......
Many thanks to all of you who have provided explanations of what purple fringing is and how it happens and how to avoid it - but --- if you do have an image with this affliction , what do you do in Lightroom or Photoshop to fix it?
02-22-2012, 06:58 PM   #20
wlachan's Avatar
LR is quite effective on removing CA.
02-22-2012, 07:19 PM   #21
Maybe this belongs to another Forum section - but ---
QuoteOriginally posted by JohnBee Quote
Would you mind pointing me in the direction of the Photoshop trick?
Thanks
02-22-2012, 07:30 PM   #22
Although not photo shop, I use PSP X4 which has purple fringe removal and also CA removal, but note not all CA removal tools are created equal. I did an evaluation about 6 months ago where I posted a raw image with very bad lateral CA and let forum members use their tools on it. For plane of focus lateral CA you want a tool that rescales the layers as this improves edge sharpness, for out of focus regions you want a fringe removal tool that you can select the colors and the range of fringing, in terms of pixels to remove what you want
02-22-2012, 08:27 PM   #23
mikeSF's Avatar
i mostly just use the chromatic aberration sliders in the lens corrections tab of ACR, do you have this? it makes it easy to shift out those colored fringes. alternatively, i pull down the purple saturation slider (also in ACR), sometimes the cyan one. in the past i would slowly decolorize the fringe with the sponge tool - too tedious but good if the other methods are not practical. i have also used the color sample tool to remove the offending color in a duplicate layer and then painted back in the affected with unaffected areas. i have a few more but that should do.
02-22-2012, 09:39 PM   #24
Laurentiu Cristofor's Avatar
Yes with CA youo see all "fringing" especially in the out of focus zones.
But the fringing you see is not purple fringing there is a better example posted you see CA and this would be present on film as well as digital, true Purple Fringing is a digital only issue
I call the car sample "purple blooming" Others call it sensor blooming. But if you check the wikipedia article on purple fringing you will see that the definition is quite generic and the sample provided is not one where purple surrounds a bright spot - it is closer to what wlachan posted.
02-22-2012, 09:43 PM   #25
QuoteOriginally posted by mikeSF Quote
Thanks, mikeSF. Lens correction doesn't remove purple fringing for me, but reducing Purple saturation does in both Lightroom and Photoshop, it's a pity about the effect on the purple tones in other parts of the picture . I hope that LR4 will make this a bit easier.
02-22-2012, 09:44 PM   #26
QuoteOriginally posted by Laurentiu Cristofor Quote
Except that there is no need to redefine CA as purple fringing. For me, what people talk about purple fringing on digital , they are discussing sensor bloom, because CA has been called CA for fifty years with lenses (at least) with film lenses, you dont need to call it something new just because it is now digital.
02-22-2012, 09:46 PM   #27
Anvh's Avatar
Very nice artiacle about CA and he also talks about PF
http://toothwalker.org/optics/chromatic.html
What most call PF is actually longitudinal chromatic aberration.
And it isn't a sensor thing, at least not for the most part.
If it was then tell me why it does not show up with all the lenses?
02-22-2012, 09:55 PM   #28
QuoteOriginally posted by Anvh Quote
Chromatic aberrations
But really all the article does is say that all fringing, except sensor bloom is really CA and that is the end of it.
02-22-2012, 10:04 PM   #29
Happy to call it whatever - sensor blooming sounds ok to me. It's the removal that's the hard thing to do
If my first attempt at attaching a picture works , you'll see that "purple blooming" applies in 2 ways, where if I remove the unwanted purple edges around the icing, the agapanthus petals on the left are also affected (not that it bothers me in this happy-snappy) ... fyi, the lighting is indirect daylight coming from the south (Australian orientation), so not really backlit.
02-22-2012, 10:25 PM   #30
When I asked Pentax why the 77 Ltd exhibited purple fringing a Pentax technician explained that it was mainly because the FA lenses are optimised for film therefore do not focus the light at exactly the right focal plane because the sensor is much thinner than 35mm film.
I am sorry I cannot remember exactly how he explained it so this explanation may be a bit thin so I hope someone else may be able to explain it in a more technical way.
k-mount, pentax lens, slr lens
Does the K5 Amplify Purple Fringing? PixleFish Pentax K-5 27 01-07-2011 01:48 PM
Purple fringing with 31ltd DanielT74 Pentax SLR Lens Discussion 7 11-05-2010 06:11 AM
Purple Fringing stevewig Digital Processing, Software, and Printing 13 09-08-2010 01:01 PM
DA40mm and purple fringing trevorgrout Troubleshooting and Beginner Help 9 07-10-2010 03:46 PM
Pentax 43mm f/1.9 limited & purple fringing? MojcaP Pentax SLR Lens Discussion 10 05-27-2010 02:11 PM
All times are GMT -7. The time now is 04:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
